rewiring DRL's to the crappy fog lights
Old Mar 11, 2010 | 12:13 PM
Rottidog's Avatar
Question rewiring DRL's to the crappy fog lights
On my blazer I have those almost useless stock fog lights. What I want to do is rewire the DRL's to the fog lights, install 4300K HID's for high beams & do the quad beam fix. BUT, like Kyle has a switch for his DRL's I want to have the quad beam switchable. Then use the dash switch from the fog lights to power rear aux. lights. I would have to change the wiring in the switch or somewhere because when the high beams are on it shuts off the fogs.
Am I dreaming or is it possible?
Old Mar 11, 2010 | 12:20 PM
The dash switch is a single momentary switch. When you press it, the BCM sees that it has been pressed and turns on the fog lights. To use that switch elsewhere, you would have to make up a latching relay setup. Check out the12volt.com for schematics of a latching relay.
Anything is possible. It just depends on how motivated you are!
Old Mar 11, 2010 | 01:30 PM
Jonas's Avatar
Jonas is on a distinguished road
Default quad
on my 97 i have a switch in the dash for quad beam.
It was used for 2 hella's before but when i installed my hid kit i spliced those 2 power cables into the powelines for the high beams.
Light on = low beam.
Real high beam switch = only high beam.
light on + dash switch = quad beam.
Old Mar 11, 2010 | 02:17 PM
Rottidog's Avatar
right on... thanks you two, it looks like I have a LOT of thinking to do & research.
1st will be getting the DRL to run the fog lights
2nd will be a switched quad beam for the high beams which will have 4300K HID's
I think that'll be really slick towing the boat in the summer on a moonless night
rethinking it I may use the fog light switch as the quad beam switch then installing another switch for the rear lights
hmmmmm
SWANNERZ
Aug 13, 2014 05:05 PM
hoebob69
May 17, 2014 01:24 AM
S10BlazerFTW
Dec 16, 2013 03:02 PM
carguy798189
Nov 4, 2010 08:25 PM
nslide10
Jul 9, 2006 02:29 PM
