Step/courtesy lights...
Old Aug 7, 2018 | 11:25 PM
Bepjer28's Avatar
Bepjer28 is on a distinguished road
Default Step/courtesy lights...
I want to add lights to my door panel... I think they are called step lights... The lights will illuminate the ground when the door is opened... I haven't taken the door panels off but i was wondering if there is anything in the door that is powered only when the door is opened or when the dome light is on... Basically i am wondering how to wire the lights to light up with the interior lights...
Old Aug 8, 2018 | 09:22 PM
frank1's Avatar
frank1 is on a distinguished road
I made these door lights for my 83 Buick regal ,They are from a stainless steel BBQ grill side panels. I got LED light strips from Princess Auto and glued them in the fined openings. The wire is then runed back through the flexible door conduit and attached to the door light switch. You can rough wire them and tape them to the door panel first to see where you want them before you cut a hole in the door and you can also wire them up with a 9 volt type battery for testing ,also you can polish then with a wire cup brush to get a brushed look finish. If you can do the testing in a garage ,able to turn off lights, you can real get the effect on how they will work when permanently mounted.
Old Aug 9, 2018 | 05:28 PM
Bepjer28's Avatar
I'm planning on 2 more sets of these and just stick them to the bottom... Drill a hole in the door panel to run the wire... I was just wondering in there were anything in the door wired to come on with the door switch...
Old Aug 14, 2018 | 01:00 PM
N. Jensen's Avatar
I have been thinking about this, too.
They do have cheapy kits on eBay...they are powered by batteries and the off/on is triggered via a magnet. The magnet is attached to the bottom of the door frame, and when the magnetic bond between the magnet and light is broken (like when opening your door) they turn on.
I don't want to go that route.
From what I've seen inside the door...I don't believe there is a power source that turns on when the door opens.
Like frank1 said, best to run the wires through the flexible poly conduit tube.
Old Aug 18, 2018 | 04:19 PM
Bepjer28's Avatar
I agree... I'm wondering how I'm going to get behind the dash especially the passengers side...
Old Sep 18, 2018 | 09:35 PM
G0LFADD1CT's Avatar
G0LFADD1CT is an unknown quantity at this point
On my rig I can easly remove the glove box door and access the door switch. Don't know what year your rig is but mine is a 2000.
Old Sep 19, 2018 | 09:13 AM
N. Jensen's Avatar
Yeah, the glove box should just swing down after pushing up the little wire thing up. It's in the top left corner once you open the glove box up.
03Blazers
Jan 17, 2019 11:21 PM
7outblazer
Aug 12, 2010 05:55 PM
Dutch_EXP
May 3, 2009 01:09 PM
cage47
Apr 20, 2009 01:32 PM
myetman
Jul 27, 2006 02:18 PM
