Stereo Wiring Help!
Old Apr 17, 2014 | 12:19 PM
Blazer1974's Avatar
Blazer1974 is on a distinguished road
Default Stereo Wiring Help!
I have a 74 K5 blazer and I would like to install a stereo and 4 piece speaker system. The only problem is all the preexisting wiring is completely gone and there is no stereo in the truck already. I've looked for diagrams and videos, but none of them showed how to wire the truck from scratch. I have basic wiring skills, but some help with this would be great.
Old Apr 17, 2014 | 12:46 PM
cubawashere's Avatar
cubawashere is on a distinguished road
I can possibly help you, but you would have to find some kind of wires (whether cut or not) in the dash area and take clear pics to see what you are working with. Maybe different angles too.
Old Apr 17, 2014 | 03:42 PM
Stock stereo or aftermarket?
If aftermarket and you are starting from scratch, all you will need to run from the truck's main harness to the stereo is the +12V constant, ground, and ignition source wires. The rest of the wires will go to the speakers you will install. A bit of time with a multimeter under the dash at the fuse box will help you identify the +12V and the switched ignition source connections that you will have to make.
phxjosh
May 27, 2013 03:01 PM
denver jimmy
Oct 4, 2010 12:56 AM
bob_elder
Nov 1, 2009 11:34 PM
robar144
Apr 11, 2007 01:11 AM
TONY_ton
Sep 12, 2005 07:05 PM
