Sticking Ignition switch easy fix
Old Sep 22, 2013 | 08:49 PM
John Heise's Avatar
John Heise is on a distinguished road
Default Sticking Ignition switch easy fix
Hello all,
One of my 1st posts here, but I have looked in on the site a number of times for info. I have had a problem, and seen it talked about on here, where the key won't always turn all the way off when I go to shut my 03 Blazer 2dr, 4wd off. I saw where the parts were going to be over $400 dollars to fix it, and I don't have that kinda money.
Well, the other day it pulled that stunt on me again... at the house in front of my garage... and I decided enough was enough... I know that the little solenoid switches tend to stick after a while and that this was causing my problems, so I decided to try something. I unbolted the console and lifted it up as best as I could and sprayed everything around the shifter, and especially the solenoid switches VERY heavily... I then sprayed around the ignition. I turned the ignition on to the point where I could start pushing the button on the shifter and started working it... and I sprayed the area some more... After about thirty seconds on working the shifter button, I turned off the ignition and the key came out normally. I then sprayed into the ignition and worked the key back and forth several times, with NO problems. I can't guarantee it is a perfect fix, but so far it has worked fine for me..... I never thought that I would have to replace the solenoid... just needed to get some spray lube on it.... well I did... and it worked!!!
Just my .02 of a quick and easy fix idea....
Old Sep 23, 2013 | 12:32 AM
Thogert's Avatar
Sprayed with what?
Old Sep 25, 2013 | 04:46 PM
John Heise's Avatar
OOOPPPsss.... I guess it would help if I said what I used. Sorry about that. I used a standard Silicone spray lube, for electronics and for softening and protecting the weather stripping. And now 4-5 days later... still not a single problem... which is saving my fuel pump as well, as it doesn't turn on and off with me fighting the ignition switch and turning it on and off.
John
Old Sep 26, 2013 | 11:13 AM
Thogert's Avatar
Cool, I was worried for a min that you might have used something conductive / flammable.
newguy
May 8, 2015 09:44 PM
r_marczak_83
17
Mar 9, 2013 10:33 AM
wrenchheader
Sep 2, 2012 05:31 PM
m_eason_98
Jul 27, 2009 08:32 PM
Dodge Guy
Oct 25, 2006 08:48 AM
