Stock fog light switch Aftermarket lights
Old May 16, 2011 | 01:07 AM
whitezr2blazer's Avatar
whitezr2blazer is on a distinguished road
Default Stock fog light switch Aftermarket lights
I want to put a stock fog light swith with aftermarket lights, i was wondering how to wire it and if there was anything speciale. if so does anyone have a dieogram
Old May 16, 2011 | 07:00 AM
What are you driving? Do you already have fogs?
Old May 16, 2011 | 12:10 PM
I have a 99 zr2 blazer no it didn't have fog lights to start. I just got the switch from the local salvage yard.
Old May 16, 2011 | 12:58 PM
The switch is a momentary ground switch and requires programming changes to the BCM to activate the fog light circuitry provided your truck has it already.
You are much better off to put in your own switch and wiring than to mess with the stock stuff.
Old May 25, 2011 | 08:25 PM
ok what if I want to put in a bumper with stock fog lights is it still as hard as wiring aftermarket lights?
Old May 25, 2011 | 09:06 PM
mdehoogh's Avatar
It doesn't matter if the lights are stock or aftermarket. I used to have my fog light switch control a set of aux lights on my grill guard but ended up putting them on their own independent circuit. You can get an SPST relay and switch for like $6 at radioshack
Like swartlkk said though, the oem fog light switch isn't a standard on/off switch and it would require a change to the BCM if your truck didn't originally come with the fog lights. It might be possible to just swap in a new BCM but I know almost nothing about it (other than some of the quirks **** me off)
Old May 26, 2011 | 11:34 AM
BCM's, like PCM's, must be programmed to your truck so they just cannot be swapped.
With some creative wiring you can make the momentary switch work (google "latching relay" or look it up on the12volt.com), but it is by far easier to use a new switch to activate the fogs.
Old May 26, 2011 | 01:46 PM
RangerG's Avatar
I had the same fog lights idea as you. Even installed the switch panel, but scrapped the idea due to the problems listed above. I found a DIY on ZR2USA on how to do it, but it sure doesn't seem worth the fight.
SWANNERZ
Aug 13, 2014 05:05 PM
Kaegael
May 21, 2014 11:29 PM
Kai
Nov 2, 2010 11:36 AM
tmurph01
Apr 13, 2010 02:27 PM
S10Blazer
Dec 30, 2007 11:25 PM
