Stock plug gaps ?
Old Dec 5, 2017 | 07:16 PM
95teal4x4's Avatar
95teal4x4 is on a distinguished road
Originally Posted by JTWard
I agree with that, But I installed a MSD Coil, Cap & Rotor and a new set of AC Delco Professional wires. I wanted to step as I don't do a lot of long hauls. Mostly short errands. It's only 0.10 over and the plugs are identical side by side ?
Changing your spark plug gap will make the coil have to put out more voltage to jump the spark plug gap. By doing that, it in most cases will reduce the duration the spark is in the gap. Even .010 over should not be done. At least in my opinion. The manufacturer sets the specification to match the programming in the pcm. By changing the gap, you are messing with the ignition systems way of operating. Putting a bigger ignition coil in it will not change how much voltage it puts out. The ICM controls the coil and puts out as much spark as it needs. If your current spark plugs are gapped .010 over factory spec, i would re-gap them back to factory spec. Just my 2 cents
Old Dec 5, 2017 | 07:18 PM
odat's Avatar
Even tho I agree with checking the gap on new plugs, Platinum plugs are not to be reset from the factory setting, If you feel the need to reset be care full on how you twist and tweak the tang as you can ruin the coating. IMO if you have one that is out and needs to be reset return it for another one. It will be cheaper for you in the long run
futuredoc
Oct 7, 2024 06:14 PM
4.3l trouble
Apr 7, 2019 06:54 PM
Spectreblazer
Feb 13, 2010 04:59 PM
sincbr
May 17, 2007 01:19 PM
boulonman
Mar 5, 2007 05:10 AM
