strobe bulb location in 1st gen taillight
Old Nov 25, 2009 | 02:31 AM
urbex's Avatar
urbex is on a distinguished road
Default strobe bulb location in 1st gen taillight
Yes, I am authorized to have emergency strobe lights in my vehicle, and I am well aware of the penalties for the illegal use of them
With that outof the way, I'm trying to decide where in the taillights to put the strobe bulbs. My setup is a Whelen Hide-A-Way with the pop in style regular strobes, not LED. In my Cherokee, it was easy as the running lights used both the dim filament in an 1157, and a seperate 1156. I just pulled the 1156, and siliconed the strobe in it's place. I see I'm not that lucky on my '91 S-Blazer.
I have no problem drilling a hole in the housing, just wondering if I should put it in with the taillight/brakelight section on the top, or with the running light in the middle? I was orginally thinking with the running light, as it would put the strobe bulb more or less parallel to the ground, and wouldn't mix in with regular hazard flasher use as well (thinking if I had the flashers on with the strobes, the strobes would over power them, and make them pointless to have on at the same time). But then I figured the strobe is going to overpower them regardless of where I mount the bulb, so worrying about that was pointless. Then I was also concerned that putting it in the middle cavity would put it too close to the lens and dividers, possilby melting them.
Is the light from a strobe bulb directional enough (or at all?) to even worry about whether it's mounted level or not?
Old Nov 25, 2009 | 05:20 PM
Blazin_Jason's Avatar
I would mount them in the backup light portion. It shouldn't matter which orientation the strobe is.
Old Nov 25, 2009 | 05:41 PM
neo71665's Avatar
Before I took them out I had mine in the running light area (the 194 bulb). I ran them for about a year with no problems but I didn't run them very long when I did have them. The only reason why I left them out was cause I didn't wanna drill out my new tails.
Strobes are not directional at all.
Old Nov 25, 2009 | 06:58 PM
abig84's Avatar
check ebay. maybe they have some already tapped for a strobe bulb. i bought a old fire dept brush truck and it had them already in the back. someone either spent a lot of time on this or they bought them from somewhere
well... i guess it dont look to bad, just use a hole saw then a file to make the squares
knitter0217
Mar 21, 2012 09:31 PM
hirni
Feb 2, 2012 11:03 AM
jlitzner
Aug 16, 2011 03:07 AM
FoxTrota
Sep 12, 2008 12:05 PM
