Stuck/sticky brake light switch
This morning when it was below zero, my girlfriend was taking the jimmy to work, and she said the brake lights stayed on, she had to pull the brake pedal back to get them to turn off.
I noticed when it was below 30 degrees I would hear the switch "click" when pressing the brake like the switch was getting stuck, but it would always turn off because it wasnt super cold.
Would it just be easier to replace the brake light switch, or can I try to clean the one that is in there.
Also, Is it safe to lube the brake lever bracket? If so, what kind of lube should i use. Thanks
Anyone? I am thinking I should just replace it instead of cleaning it.
Denominator
07-09-2011 09:07 PM
gmbwrenchn
10-28-2010 07:30 PM
SCBlazer96
04-16-2010 08:39 PM
