SWR Meter
Old Apr 13, 2013 | 12:55 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
I have burnt finals out of a stock unit before cause it wasnt properly tuned.I have no doubt it will happen alot faster with lenear amped unit
Old Apr 13, 2013 | 01:00 PM
Twip's Avatar
Originally Posted by WitchingHour
For a barefoot unit pushing out four watts, not so much. If you run a peaked and tuned radio and/or run a kicker with it, then it becomes critical to have your SWR properly tuned.
nothing does only 4 watts anymore. they will dead key at 4, but once you get to jaw-jackin in them, they will swing up to about 12 watts.
i personally like my dead key at 30 watts, and then it swings to 45 watts when im talking.
Old Apr 13, 2013 | 02:07 PM
WitchingHour's Avatar
WitchingHour is an unknown quantity at this point
Not out of the box, unless it's on single sideband. They can go up to 12 then. An AM CB radio, by law, can only be four watts, and that's what they'll push out of the box. If you bought one which swung more than four, then it was either peaked and tuned (which is pretty common), or it was a 10 meter ham radio converted over to 11 meter Citizens Band.
§ 95.410 (CB Rule 10) How much power may I use?
(a) Your CB station transmitter power output must not exceed the following values under any conditions:
AM (A3)—4 watts (carrier power) SSB—12 watts (peak envelope power)
(b) If you need more information about the power rule, see the technical rules in subpart E of part 95.
(c) Use of a transmitter which has carrier or peak envelope power in excess of that authorized voids your authority to operate the station.
The FCC may not be able to do much as far as enforcement goes against individuals in mobile units, but they very well can against manufacturers. Know of quite a few home basers who've been tagged, as well.
As for me...
I also have an Elcan one pill or a Dave Made five pill I can put behind it if I ever get the mind to.
Old Apr 13, 2013 | 05:03 PM
Twip's Avatar
As for me...
i know that you are correct, and i dont want to get in the politics and all that, i am just saying from what i see, most of them swing to 12 watts. from what was explained to me several years ago, is that when the FCC checks those, they only dead key them. of course i could be wrong, i am just going off of what i was told. havent done much research myself on it. but i do know that the home baser's that are putting out some power do have a better chance of getting caught. and i know that me putting out 45 watts is technically illegal, but i am not "advertising" anything. so much gray area with some older stuff like CB radios. i've never had a problem with the law, but i am, at least right now, only using mine in the line of work that i do.
Old Apr 13, 2013 | 06:40 PM
The advantage the home basers have in output actually isn't power... they can do a lot more with a lot less. It's that they have 11 meter long antennas which can transmit a full wave, and produce actual DB gain... if someone tells you their short antenna produces gain, that's incorrect - transmitting at less than a full wave, there is only DB loss.
It's doubtful the FCC is going to take much of an interest in a 45 watt radio. Now if you start cranking out thousands and disrupt other communications, it becomes a whole different matter, which is why they end up busting home basers.
Old Apr 14, 2013 | 10:38 AM
I know I had their attention when I was younger LOL.Those were the days.I had this older guy as friend he tweeked all my radios and taught me about amplification and home base attenas.The starduster tripples were bad to the bone.You guys may have a clue or not IDK.You could rotate them and lock on somebody`s signal.Anyone inbetween was dead noise.10ft higher than they should have been I had a hell of tower.I was 14 and put it up by myself.Tied here down with cables.
radiokid
Dec 23, 2011 11:41 AM
S10Blazer
Jul 8, 2008 12:32 PM
zombiewoof
Feb 25, 2008 06:51 PM
drperry
Mar 9, 2007 09:57 PM
dropd4door
Feb 21, 2006 11:43 AM
