Voltage Issue
Old Oct 21, 2018 | 04:06 PM
Blazer112's Avatar
Blazer112 is on a distinguished road
Default Voltage Issue
Great
Old Oct 21, 2018 | 08:22 PM
cleburne red's Avatar
Originally Posted by Blazer112
Hello,
Any ideas why the connector to my map sensor reads 70 volts? The base line connection reads the nominal 5 Volts. I have randomly check other electrical points and they read 12 volts. I have a 2004 Blazer ZR 2 and have owned it since day 1. My Blazer started missing badly while cruising at 40mph and the check engine light and subsequent scan identified the faulty sensor. I changed it but the problem persists. Thank you for your time.
I don't even see how that's possible. The battery is only 12v. There is no voltage higher than that in the vehicle, except for the ignition, and that's probably over 20k volts.
Is it reading 70vac or DC?
Old Oct 21, 2018 | 09:49 PM
Blazer112's Avatar
Default 70 dc.
Thanks
Old Oct 24, 2018 | 09:06 PM
So, that's the only place you're reading that high of a voltage? Sounds like you need to spend a day tracing out wiring and figuring out where it's coming from!
You would think if it was the alternator, everything would be high, not just that one circuit
Edit: even if it were possible to be induction, wouldn't that be AC? Can't really induce DC, can you?
Old Oct 24, 2018 | 09:35 PM
ChuckNTruck's Avatar
Just to make sure, test you alternator and see if it is putting out any A/C voltage.
Many auto parts stores can bench test it for you for free.
https://www.knowyourparts.com/techni...-misdiagnosis/
Old Oct 24, 2018 | 10:50 PM
G0LFADD1CT's Avatar
G0LFADD1CT is an unknown quantity at this point
I would think that in order for the alternator to put out AC voltage the rectifier would be bad, but you would see high voltage in basicly the whole rig. Very puzzling.
'93BLZR
Jul 25, 2020 09:49 PM
Big'n
Jul 28, 2018 08:17 AM
Pagerboy
Jul 18, 2013 10:20 AM
marksoftball
Feb 28, 2009 12:15 PM
Sunshine Coaster
Oct 20, 2007 12:24 AM
