A way around it?
hello,
I'm curious if there is a way to bypass my "lights on" sensor ( in my right dash speaker grill) so that I can let my engine run while it's dark out & not have any of my exterior lights illuminated? Thanks for any help or info. I appreciate it. |
put on the Ebrake
Originally Posted by StarScreamin
(Post 696497)
hello,
I'll have to look, but you can replace the sensor with a resistor. I forget the exact size as I did 15+ years ago. Bought a few of them from Radio Shack, that tells you how long ago. If I remember I'll take a look tomorrow and let you know.
As for the dome override trick, only works for certain years and you push it in and out four times. |
On my 2000 Blazer just push dome override 4 times and disables the lights until next time you start it. Here's a link on this forum with some other options.
https://blazerforum.com/forum/2nd-ge...0-blazer-7052/ |
Unplug the sensor, and wire a resistor from one prong to the other.
if you have a 98 you need an 860 ohm resistor. if it's 99 and up, you need a 2.2k ohm resistor. |
Originally Posted by chevyriders
(Post 696557)
Originally Posted by AJBert
(Post 696603)
There's the answer! I may still have some of the 2.2 ones in my console.
Yes, my apologies for the lack of info concerning my blazer. It's a '99 4x4. And not only do i want my headlights off, I also want the option to shut off all my exterior lighting. If ur wondering why, it's for the simple fact of hunting. I just think it would be great to be able to turn my lights on/off wen I want to.
(Post 697036)
Be sure to post your results. Does the Dome Override button trick work on yours? |
| All times are GMT -5. The time now is 09:38 AM. |
