Weird Fuse Issue
Old Mar 1, 2011 | 04:58 PM
huntersblaze's Avatar
huntersblaze is on a distinguished road
Default Weird Fuse Issue
Last night I noticed that my left rear parking light (light that emits from the brake light when the headlights are turned on) wasn't working. So I did the following:
1. Check the bulbs- they looked good
2. Checked the fuse, it was shot so I replaced it. Still not working
3. Checked the new fuse, it immediately blew so I replaced it again. This time the parking light is working, but before I start to re-assmble the tail light they stop working.
4. Check the fuse again, this time its fine, I still suspect that the bulbs are fine but replace them anyways, still with no luck.
I am not experienced in electrical/wiring but I have concluded that its not the fuse and not the bulbs, so is there something wrong with the wiring and how do I fix it?
ps. the bulbs work when the brakes are applied, they just don't emit light when its dark out.
Old Mar 1, 2011 | 07:47 PM
BlazinClinton's Avatar
BlazinClinton is on a distinguished road
replace the bulb. try again. sometimes bad bulbs look good still and can short wiring out. ive been there dun that type of thing.
Old Mar 1, 2011 | 08:49 PM
How do the terminals in the bulb sockets look? I have repaired quite a few sockets where corrosion had shorted across terminals.
Old Mar 23, 2011 | 03:23 PM
I just checked the terminals and they looked fine, I don't think it would be the corrosion in the terminals anyways just from the fact that both bulbs stopped working at the same time. Im really at a loss with this one, other problems occurred right around the time (maybe the same time) the left rear parking lights failed, including:
fog lights stopped working (the light indicator on the button doesn't light up either)
The function where all the parking lights blink when remotely locking/unlocking has also ceased to work.
Maybe these problems could be related so I though I would mention them, otherwise I still have no idea.
Old Mar 24, 2011 | 03:07 AM
TNatus23's Avatar
TNatus23 is on a distinguished road
Any Chance Wires Could of been Pinched . . In an accident or back into Somethin. .?
Old Mar 25, 2011 | 12:25 PM
I actually did back into a post on the passengers side about the same time all my electrical problems started happening. It wasn't very hard but it gave me a little jolt and bent the corner of the bumper a bit. Even though the problem is on the drivers side could this be it? Where would the problem be? I have inspected the wires a far as from the bulbs to where they enter into the body and they look fine.
Joann
Oct 14, 2013 10:33 AM
AustinBlazer
Jun 4, 2013 10:35 AM
gERgMan
Sep 6, 2008 07:27 PM
johnpimentel72
Apr 23, 2008 08:05 AM
texastrails
Aug 25, 2007 04:10 PM
