What is this? *Help*!
Old Apr 16, 2020 | 01:32 PM
ChaosFox's Avatar
ChaosFox is on a distinguished road
Default What is this? *Help*!
Hello i was changing spark plug wires, cap, and rotor on my 2000 2D 2WD Blazer ajd accidentally ripped out what seems to be a sensor, can i still drive? It will not go back in🙄
Old Apr 16, 2020 | 02:03 PM
Looks like your temp sensor. You can drive it, but it may not run right.
Old Apr 16, 2020 | 02:09 PM
ChaosFox's Avatar
So coolant temp gauge?
Old Apr 16, 2020 | 03:07 PM
I'm not sure if that one is for the gauge, or to let the PCM know the coolant temperature for fuel mixture purposes, or both. Does the temp gauge work?
Old Apr 17, 2020 | 02:22 PM
LesMyer's Avatar
You will have to fix it or you will most likely be running very rich and SES light will come on. It is for both gauge and fuel injection sensor - the PCM uses this sensor for both. It's cheap and a common part. Just replace it.
Old Apr 17, 2020 | 06:21 PM
ChaosFox's Avatar
i replaced it and (with almost all these sensors) it seems bigger and a TINY bit longer than the oem, it won’t thread ALL the way through theres still about 1/8th of an inch of threadlocker and thread left. Is it safe to leave and plug back in? Most positive it isn’t cross threaded.
Old Apr 17, 2020 | 11:19 PM
It should be tapered pipe thread, so that's perfectly normal. As long as it's tight and doesn't leak.
Old Apr 24, 2020 | 01:04 AM
jimspahr@msn.com's Avatar
How's it running at start up? How's the temp gauge doing ?
danp95
Feb 3, 2013 06:27 AM
wahdcw
Dec 25, 2010 10:47 PM
blueblAZer99
Nov 10, 2008 10:24 AM
BlazerSS
Performance & Brainstorming
Jun 29, 2007 06:12 AM
carpentercb
Mar 9, 2006 08:57 PM
