What is the ground under the ABS ground?
Old Aug 30, 2012 | 05:50 PM
eljorgin's Avatar
eljorgin is on a distinguished road
Default What is the ground under the ABS ground?
hi, on a 2003 4x4 blazer, can someone help me identify the ground that's screwed to the chassis a few inches under the ABS ground (under the airbox)? there is some kind of yellow plastic connector attached, which in my case is unplugged, but I can't find any loose connection.
I've looked through dozens of diagrams but couldn't find an answer.
thanks!
Old Aug 31, 2012 | 07:49 PM
MyHeadache's Avatar
MyHeadache is on a distinguished road
item 4? G117?
File Type: pdf
Old Sep 9, 2012 | 09:42 AM
eljorgin's Avatar
thanks but no, this diagram seems to be of the dashboard backside, whereas the abs module ground is directly under the airbox, between radiator and windshield washer fluid container.
Could it be that it belongs to the right front wheel abs sensor, or are these un-grounded?
Old Sep 9, 2012 | 11:05 AM
Rottidog's Avatar
Take a picture of it, that'll help.
When you said yellow I though of the Airbag Sensor.
Old Sep 12, 2012 | 11:47 AM
MyHeadache's Avatar
Old Sep 13, 2012 | 05:38 PM
eljorgin's Avatar
thanks for the great link, Myheadache! still it's not a 100% clear to me what it is. maybe the battery fuse?
@rottidog: I'll take a pic on the weekend. If it's the airbag sensor I better not fiddle with it, I guess!
Old Sep 19, 2012 | 05:42 PM
eljorgin's Avatar
Ok, confirmed, it's the ground for the battery fuse. thanks for your help guys!
Old May 21, 2019 | 03:08 PM
GeorgeLG's Avatar
BTW, another way to prove my theory is plug the right horn back in and back probe the positive wire with a multimeter. I bet that you get low or no voltage when you activate the horn because the load cause a big voltage drop through the corroded location. If you unplug the horn and do it again you’ll get a higher voltage with no load. Current goes up under load and ohms law describes a voltage drop across the resistance of the corrosion.
George
Old May 21, 2019 | 10:04 PM
cleburne red's Avatar
Hey, uh, George... Think you posted in the wrong thread lol
Dabman
Apr 29, 2016 06:14 PM
mickey_bigdaddy
Nov 1, 2015 08:17 PM
Ryanmatt135
19
Oct 20, 2014 09:07 PM
88beast
Mar 22, 2010 06:54 AM
jstutzman
Mar 11, 2009 07:04 PM
