White dome and map lights!
Old Apr 14, 2012 | 06:58 PM
96chevblazer's Avatar
Default White dome and map lights!
Hey guys I got a 97 blazer with a sunroof and I want to replace the ugly yellowish bulb with white LED's in the map, dome lights, and rear light. Now having the sunroof makes the lights different than most other blazers as I don't have the swivel map lights for the squarish dome light. I don't have a picture of the map lights but they are the push button ones, like the ones here
95-97 BLAZER JIMMY DOME LIGHT INFO CENTER W/HL 96 !!! | eBay
And the dome light is an oval one.
Also I will replace the rear hatch light.
So I need to know what # of light each are and if someone could find me white LED's that will fit directly that'd be great, Thanks
Old Oct 30, 2012 | 01:23 PM
Gkolo1's Avatar
Gkolo1 is on a distinguished road
How do you remove the covers to get at the bulbs ?
I have the same set up in a 97
Old Oct 30, 2012 | 01:53 PM
Thogert's Avatar
You should be able to (very carefully) use a flathead screwdriver and pry on the edge and they should pop off.
Side note: They should be T10 bulbs.
Old Oct 30, 2012 | 03:03 PM
Gkolo1's Avatar
Ok thanks, For some reason the front map/dome lights dont work, But the useless little cargo light in the back works when you open the doors.
No fried fuses.
Old Oct 30, 2012 | 04:45 PM
247monster's Avatar
i just put all blue leds in my dome, dash, cargo and gear light (the light that shows what gear your in for blazers with the shifter on the floor lol) i love it man its a cool custom look and alot better then coloring light bulbs with sharpies lol =)
97blazer8488
Nov 4, 2015 04:48 AM
Aeratvs
Apr 15, 2012 07:38 AM
crazyjust
Apr 5, 2010 10:35 PM
countryguy1713
Apr 20, 2008 11:23 PM
RQuickDraw
Oct 27, 2006 09:38 PM
