Wiring diagram for adding more lights?
Old Nov 18, 2014 | 07:42 AM
jbrooks19's Avatar
jbrooks19 is on a distinguished road
Default Wiring diagram for adding more lights?
Does anyone have a diagram showing how to wire a lighting system? I know how to do ones with a fuse, toggle switch, etc... But what is the deal with using a relay? BTW, i'll be mounting 4 medium sized lights on my roof rack..
Old Nov 18, 2014 | 08:18 AM
Jamaroon's Avatar
relays are used when you need more power than a switch is rated for. The relay will have the main power in (from battery) and out (to lights) as well as secondary power in (from switch) and ground.
So you would run power from a constant hot or hot only when ignition is on (your choice) power supply (ie. tap into the fuse box) to your switch, then from the switch to the relay. Then you would run power from the battery to the fuse then relay and then relay to the lights.
Old Nov 18, 2014 | 09:24 AM
jbrooks19's Avatar
Do you think running them with a relay would be a good idea?
Old Nov 18, 2014 | 10:59 AM
Jamaroon's Avatar
It would likely be better yes, you would have to check the ratings on the lights and switch to know if you need to or not though.
blackhawk61
Jun 1, 2014 09:06 PM
phxjosh
Oct 30, 2013 10:03 AM
TheSzokes
Sep 13, 2008 03:48 PM
sysmex
Performance & Brainstorming
Jul 14, 2007 07:46 PM
The Franchise
May 31, 2006 12:28 AM
