99 Grand Prix Power window switch smoked and died
Old Apr 6, 2010 | 08:30 PM
ussexplorer's Avatar
ussexplorer is on a distinguished road
Default 99 Grand Prix Power window switch smoked and died
I know this isn't a blazer. But I figured somebody might tell me what is up. While rolling up the window on the driver side. The window struggled for 5 sec and finished rolling up. Afterwords I noticed smoke from the power window switch cluster on the driver side. Well I rolled it down (no smoke) and up (smoke). So I removed the door panel and checked everything out. Lubed all the railings. The power window went down but when up, smoke. Then the switch finally burned out. When I jumped the switch the two wires to roll up the window. Rolls up fine just like the other three windows with no struble at all. So do I have a bad switch? Is it just that or do I have over issues? I assume just a bad switch. But this is the main driver side 4 button switch that burned up. So I don't think it will be cheap. I would hate to replace it again and again. I have never seen this problem before. Advise would be nice.
Thanks,
Josh
Old Apr 6, 2010 | 08:32 PM
zedartwo's Avatar
Go to a wreckers and find the part you need!
Old Apr 6, 2010 | 09:19 PM
Default Yes, I'm thinking that
Yes, I'm thinking that. But I wanted to make sure it was nothing more than a old warn out switch.
Thanks,
Josh
Old Apr 6, 2010 | 09:28 PM
Biohazed's Avatar
could be the motor starting to go ading extra load to the window switch. I would get a JY switch right now and if it happens again replace the motor
Old Apr 6, 2010 | 11:27 PM
rriddle3's Avatar
*Moved to 'The Lounge' since it has nothing to do with Blazers. Please carefully choose the forum section you post in.*
Little Roober
Mar 7, 2013 09:49 PM
tripovermyego
Apr 21, 2012 08:09 PM
Jharper
Street N Strip
18
Dec 25, 2008 04:37 PM
Jharper
Dec 7, 2007 09:51 AM
FatRyan
Street N Strip
16
Jun 20, 2005 12:09 PM
