Best way to build engine stand and a opinion?
Old Feb 10, 2012 | 06:00 AM
pettyfog's Avatar
Originally Posted by neo71665
I forget, is this where the ur momma jokes start, lmao.
Op
Regs have pressure ranges one won't do everything. Most tbis run about 13psi, very few run over before you blow gaskets out of it. Most carbs run 5 psi. Other forms of fi go up from there.
I addressed that.. one carburetor fits all, Adapters and Ells from plumbing dept.
There was way more changes than you think in gm ecms from 86-94. Right off the top of my head I can think of 4 in s-series alone. Wanna say 3 in fullsize trucks. Some only require a prom swap and others a rewire of the ecm and prom swap to work.
Steel sounds nice but don't forget to factor in the cost of cutting (blades), drilling (bits), welding (rods/wire), and all the electricity that takes. A hand full of nails is way cheaper since you won't eat up near as many blades.
Oh forget it. This is a pretty neat project... but if Chris cannot figure out what I mean by a old style mechanical advance distributor with a 2:1 speed reducer attached to the the crank, I doubt it's going anywhere.
Note that a camshaft is a 2:1 reducer attached to the crank. Another way would be a timing belt system off a Ford 2.3L with an extender that is bolted onto the crank pulley, a stout frame and the Cam pulley on the dist shaft
The specific distributor might be a early SBC type with an MSD pickup and appropriate circuitry.
Chris, this aint facebook. It's an ambitious project. If I reply a way you dont understand instead of ignoring it, ask me to specifically explain
You want no computer interface whatsoever for reasons implied above. The prospective buyer is not buying the sensors and injectors, he's buying the long block.
- you dont do anything with the factory fuel/spark timing component for the specific engine. Because you will spend more time fiddling with getting the setup right than you will mounting and checking out the engine.
1sttimejimmyowner
Mar 26, 2013 02:47 PM
Wexinlo
Apr 15, 2011 10:42 AM
gar63
Nov 12, 2010 01:43 PM
blazingsadle
Feb 19, 2006 12:13 AM
