Brake powerbooster question...
Old 01-18-2010 | 08:50 PM
gmbwrenchn's Avatar
gmbwrenchn is an unknown quantity at this point
Default Brake powerbooster question...
90 Pontiac 6000Le. I think I have a bad power booster. Just want to be as sure as possible. Pedal is hard when pressing down on it. While the car is off AND while running. Can I pull the vac hose and should there be vacuum there? Haven't done that yet. Just getting ideas before I blow $75 on a new one, Thanks. Any additonal checks I can do are appreciated as well.
Old 01-23-2010 | 12:24 PM
gmbwrenchn's Avatar
Pull the vac?
Old 01-23-2010 | 12:52 PM
old skool luvr's Avatar
it sure sounds like the booster had failed, and yes there will (should) be vacuum there.
have you tried pulling off the hose (and plugging it) to see if your brakes are responding the same way?
SCBlazer96
04-16-2010 09:39 PM
xderkax
01-15-2010 12:38 AM
Numba1Sean
05-07-2009 12:48 AM
Hoelgi
17
10-20-2007 09:49 PM
dashyman
01-12-2007 12:28 PM
Quick Reply: Brake powerbooster question...
