cv axle
Old Feb 28, 2011 | 05:54 PM
wild bill's Avatar
wild bill is on a distinguished road
Default cv axle
Just replaced a cv axle on my daughter's mazda. Do I need to get an alignment after doing this?
Old Feb 28, 2011 | 06:59 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
if all you replaced was the cv then no, an alignmnet is only required if you replace a steering or suspension componet, and sometimes a wheel bearing, or tires. but if you feel the alignment is off or if their hasent been a alignment on the vehicle for a few years then i would get one, it will prolong the length of your tires, steering and suspension componets and will give you better MPG's if things are out of whack.
Old Mar 1, 2011 | 06:47 AM
wild bill's Avatar
Sounds good. Thanks
Old Mar 1, 2011 | 09:56 AM
CO Chevy Dude's Avatar
CO Chevy Dude is on a distinguished road
As long as you got the strut back into position you should be OK. Assuming you had to remove the strut from the tower and the alignment was good in the first place, that is.
Old Mar 1, 2011 | 08:18 PM
wild bill's Avatar
Didn't have to remove the strut from car, just unbolted the knuckle from the strut.
Old Mar 2, 2011 | 12:04 AM
old skool luvr's Avatar
then you definately need to get an alignment done.
Old Mar 2, 2011 | 07:19 PM
ohsofly's Avatar
Ditto, you need one now, the alignment adjuster is the two big *** bolts you took out of the strut. If you ever want to get around the alignment next time, undo the 2 frame mounts on the lower control arm and take it off there instead to get the axle out and you can leave all your brake parts on, it will actually be faster that way. There is no adjustment there on your car and it would go back together the same as it was.
Old Mar 3, 2011 | 06:23 AM
wild bill's Avatar
Thanks, didn't know that.
chowell
Mar 6, 2021 09:47 PM
thrandall
May 3, 2013 04:54 PM
blajeans
Jan 9, 2013 12:58 PM
LucasMI
Jan 2, 2012 02:15 PM
jmaynard
Jul 12, 2011 01:03 PM
