cv axle
if all you replaced was the cv then no, an alignmnet is only required if you replace a steering or suspension componet, and sometimes a wheel bearing, or tires. but if you feel the alignment is off or if their hasent been a alignment on the vehicle for a few years then i would get one, it will prolong the length of your tires, steering and suspension componets and will give you better MPG's if things are out of whack.
Ditto, you need one now, the alignment adjuster is the two big *** bolts you took out of the strut. If you ever want to get around the alignment next time, undo the 2 frame mounts on the lower control arm and take it off there instead to get the axle out and you can leave all your brake parts on, it will actually be faster that way. There is no adjustment there on your car and it would go back together the same as it was.
chowell
Mar 6, 2021 09:47 PM
blajeans
Jan 9, 2013 12:58 PM
jmaynard
Jul 12, 2011 01:03 PM
