Notices
floor jack question
Old May 25, 2013 | 05:32 PM
cleburne red's Avatar
Question floor jack question
I've got this old floor jack that was given to me about 5 years ago. It's worked great, until recently it's been acting like it's low on oil. It will only jack up at the very end of the handle travel, and now won't raise under load at all.
So I went and got some jack oil for it, but when I open the plug, oil comes pouring out. I've tried it raised, lowered, locked, unlocked, everything. If I hold the jack vertically, I can open it, but it will only take a few drops.
Is there some trick I'm missing, or is it full, and it's just time to buy a new jack?
It sucks, because I just did my brakes, and now I can't get the Blazer off the jack stands. Guess it's time to get out the hi-lift.
Old May 25, 2013 | 05:41 PM
xgiovannix12's Avatar
sounds like the seals are gone in the jack. Dont quote me on it tho
Old May 25, 2013 | 05:50 PM
Yeah, that's what my googling has led me to believe, also. I think I might try and find a seal kit for it, before I trash it.
Old May 25, 2013 | 05:56 PM
Sometimes its not worth fixing... I got like 3 out back that I threw in the scrap pile....
Old May 25, 2013 | 06:05 PM
I'm just cheap! I'll try and fix it, it probably couldn't cost much for some o-rings.
Old May 25, 2013 | 06:40 PM
Apparently the tow hooks aren't a suitable jacking location. Now my passenger side has a nice upward rake to it, and I didn't even get it off the jack stand. My cobalt jack, plus a couple bricks got the job done, though.
Now I see the need to fab up some rock sliders. Other than the trailer hitch, I don't really have any good jack points.
Old May 25, 2013 | 06:49 PM
mr.vls's Avatar
Is the jack handle turning the bolt for lowering and raising. My jack handle hex end wore out and would not turn the jack bolt. I ended up drilling the end of the jack handle out and pressed in the correct size socket.
Old May 25, 2013 | 07:35 PM
It's turning it. It has a sprocket on one end of where the handle goes in, and it mates with another sprocket mounted on the main block. I can visually see it turning.
Old May 25, 2013 | 07:52 PM
rexazz2's Avatar
floor jacks dont like being put in other positions than flat on all wheels
it sounds like you might have an air lock
Try standing on end ,ram up ,valve open for 24hrs
Maybe even take out the fill plug at the same time
mr.vls
Mar 21, 2012 06:10 PM
Rottidog
Jan 11, 2012 04:47 PM
pinetopfirefighter
Mar 2, 2009 08:25 PM
gmaltese
Sep 11, 2006 12:07 AM
frankjc
Aug 7, 2006 11:12 AM
