Rancho Steering Stablizer
Anybody know What model Rancho steering stablizer I should use for my
70 K5
Also I'm upgrading to 37" x 14.50 Tires
Will I need a duall stablizer set-up or can I get by with a single....
Thanks
70 K5
Thanks
id go with a dual. they say anything bigger then a 35 you should go with a dual set up. i dont know if one brand is really better then the other. if at all possible try to get one where it doesnt have the two shocks right on top of each other right in the middle of the axle. if you are going to offroad this truck you can damage them and screw your steering up. i been running duals for about 8 years and have replaced that bottom shock about 3 times
that must be annoying Might as well weld a plate over them =P
