So I was looking for jerry cans ...
Old Nov 3, 2011 | 11:54 PM
chevytruckdood's Avatar
Default So I was looking for jerry cans ...
Talking I my brother in law about making a bumper/tire carrier/Jerry can carrier... And he mentions he came across some an I could have them.. One water one fuel just like I wanted..
Water is stamped 1943 and the fuel is stamped 1980 USMC( awesome)
Anyone know about that rust remover stuff you can put inside them and seal them up so it'll be safe for water/gas?
What about a gasket for the caps? An lastly the original paint ?
Old Nov 4, 2011 | 03:30 AM
Irocz327's Avatar
Irocz327 will become famous soon enough
I wouldn't know about any of that bud, but just wanted to say make sure you post up some pics of all of it when your done. I'd really like to getta jerry can rack for my truck, thou I might just mount them inside the truck for now, I've gotta couple of the "Newer" plastic ones at my folks house.
Old Nov 4, 2011 | 08:00 AM
Well brother in law works autocad for his business and told me to get him some specs... So hopefully next month I'll have a few dollars for metal...
Old Nov 4, 2011 | 09:59 AM
DKSDAD's Avatar
I hate to say it but you are probably better off getting new ones for the gas and water and just keep the old ones as collectables. Not knowing the full history of the cans who knows what was put in them. Good luck with the build.
Old Nov 4, 2011 | 10:13 AM
Well I was told there some stuff summit sells that eats rust and a second bottle that once done with first substance second substance coats the inside.
I'm sure I could probably make a gasket for the handles.
I'm really not wanting to let go of these because I like military gear.. And since I was in the USMC this is even better. But If I still need a better one Ill probably get another...
Old Nov 4, 2011 | 10:55 AM
AJBert's Avatar
I've got two jerry cans and just recently painted one of them. Even rigged it up so I can mount one on my tire gate, though it blocks the tail light so I only use it for off road.
Unless the inside is rusted badly I wouldn't worry to much about it. Throw a handful of small nuts, bolts, screws, etc and shake the can for a while. That'll know the rust out of there. Just make sure they are small enough so you don't dent the can.
The gasket you can make yourself from a sheet of 1/16th inch rubber. Scissors, razor, hole punch, your choice of implement.
As for what was in them before? Really doesn't matter. If there is no odors and free of rust, flush the can out with a little bit of gas and call it good. If there is an odor of something, some Dawn or other degreaser and water should take care of it. Rinse completely, let dry and flush with gas.
Gas cans should never be carried inside the passenger compartment. The build up of fumes can end up being deadly rather than just giving you a head ache.
Old Nov 4, 2011 | 11:27 AM
it took me a bit to find it but i knew i had seen one with jerry cans and taillight not blocked. im going to be building a tire swing outand im using this picture a one of my references...
Old Nov 4, 2011 | 03:00 PM
Zanders's Avatar
Zanders is on a distinguished road
you could use por 15 to coat the tank, i believe they make a kit for it.
Old Nov 4, 2011 | 08:22 PM
AJBert's Avatar
This involves moving the spare to the left with a plate. Not hard to do at all. The reason I didn't go this route, or rather the two reasons, is:
1. I'll only be carrying the jerry can offroad
2. Moving the tire further out on the swing gate plus adding a jerry can full of fuel just might over stress the swing gate assembly at some point.
My sheet metal is still in pretty good shape after 11 years and what I've put her through. I don't want to overload the swing gate and have a failure of the hinges or mounting points.
Muddy Mike 22
Performance & Brainstorming
Apr 17, 2015 01:20 AM
JesterRob04
Shows & Clubs
Apr 24, 2011 09:50 AM
Hellfish
Nov 11, 2009 09:28 PM
thevair65
Jul 8, 2007 10:39 AM
BlueBlazzin
Tires and Wheels
Jan 14, 2006 08:48 PM
