Notices
Spark plug gap& type.
Old May 21, 2017 | 07:07 AM
mrbizznitch's Avatar
mrbizznitch is on a distinguished road
Default Spark plug gap& type.
Anybody had any dealings with putting spark plug gaps at 40 instead of 60 thousands? Regular plugs, double platinum, iridium, E3's, spiltfires ??????
Old May 21, 2017 | 08:22 AM
rriddle3's Avatar
In what engine and why?
Old May 25, 2017 | 12:06 PM
chevyriders's Avatar
The only reason ive heard of people closing their gaps is if they're running nitrous... Other than that, or possibly if you're running super high compression- I don't think there is any legitimate reason to do that.
Old Jul 16, 2018 | 10:00 AM
TonyZR2's Avatar
TonyZR2 is an unknown quantity at this point
If you have a bad wire and the spark is taking a differen't path........ couldn't you temporarily shorten that plugs gap to get spark(until you get new wires)?
Old Jul 18, 2018 | 03:38 AM
If the spark jumps from the wire shorting the gap would IMHO not be a remedy.
Insulation tape would do the job on a cable, even a piece of rubber hose that you slide over the damaged part. A piece of a paper clip and a yard of electrical tape did the job once a rodent ate one of my ignition cables.
I've used both for emergency repairs which stayed on the truck for several weeks before changing cables.
Most important: use the correct type of cable. Resistor or none and correct plugs.
I've found that spark gaps in production cars can be way out of specs and still work flawless. Good measure to set them at the manufacturers spec. They have been testing that for a long time to figure the best in safe operations and economy.
Old Jul 18, 2018 | 05:57 AM
TonyZR2's Avatar
Love the rubber hose idea.
newguy
Jan 25, 2014 07:03 PM
BlueDevils
Jun 11, 2012 02:56 PM
chev5911
Feb 15, 2012 12:12 PM
