Notices
Will the fuel pump not run if out of fuel ?
Old Mar 27, 2014 | 09:05 PM
Chevy33's Avatar
Chevy33 is on a distinguished road
Default Will the fuel pump not run if out of fuel ?
I finished putting everything back together on this astro van I have been working on. I had it up on jack stands in the front fixing the leak on the timing cover. Not leaking any more. Started it after letting the RTV cure over nite. Started OK but under heavy acceleration sputtered and died. I found a vacuum leak from lines being brittle and fixed that. Still sputtered and died. The fuel guage showed a quarter tank. Only running for maybe 3 min it was getting hot. I stopped because temp sensor plug did not match up. I put a new sensor on that mated with the connector and added some water to the radiator with the motor at idle. It stopped running. After that it would not start and the fuel guage shows empty and no sound from the fuel pump. I can hear the fuel pump relay clicking but no fuel pump.
Customer states the pump was replaced last year.
Without any fuel will the fuel pump try to run?
No cel other than cam and crankshaft correlation due to previous work done and cam was replaced.
Old Mar 27, 2014 | 09:49 PM
chris015's Avatar
it will run. all i can say is check fuel pressure with a actual gauge. no less then 58lb. if its ok,its another issue.
Old Mar 29, 2014 | 05:05 PM
MrJP's Avatar
MrJP is an unknown quantity at this point
Usually, the fuel pump will only run for a short time, maybe 30 seconds or so. If the car doesn't start, you have to recycle the startup procedure.
Old Apr 8, 2014 | 09:08 AM
John Helton's Avatar
John Helton is on a distinguished road
Agree with MrJP, you can however pull the fuel relay and apply battery voltage to make the pump run as long as you want.
Old Apr 11, 2014 | 11:57 AM
abig84's Avatar
yeah it will run, i just talked about this truck in another post. working on a 96 infiniti qx56. wont start thougt the pump was bad, i can put my ear to the floor and hear it run so figured it was just weak. pulled it out and tank was completely empty. but yeah ive never seen a shut off if the tank is empty
Old Oct 26, 2019 | 09:38 AM
BIG A's Avatar
BIG A is on a distinguished road
Default Gas
That is a good way to lose the pump . Never run low , fuel cools the pump .
m3dragon
Feb 24, 2015 10:04 AM
fixer34
Mar 16, 2014 10:45 AM
exorotika
Apr 22, 2012 04:18 PM
Bonzaibob
Apr 17, 2012 11:11 AM
Blazer1965
Mar 25, 2005 12:34 PM
