Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
belltech keys review
Old May 17, 2012 | 09:43 PM
chevymobbin's Avatar
chevymobbin is on a distinguished road
Default belltech keys review
Anybody running Belltech drop keys on a 98+ 4X4 Blazer?
If so; how long have they been installed and have you had to replace anything else or encountered any issues?
Also how about just backing out the bolts? pros and cons? longevity of this setup?
here is how I priced it out in my head
Belltech keys $129-$140
Allignment $100-$150
or
Back out the bolts $0
Allignment $100-$150 (cost of belltech keys)
Old Jun 21, 2012 | 12:27 AM
NewbieT's Avatar
NewbieT is on a distinguished road
The only con to loosening the t-bar bolt's is having a loose front suspension. As far as I know, the keys allow you to essentially re-index your bars to keep the tension on the suspension and still get some drop. From reading a lot of thread's to me it seems like you would be better served saving your money from the key's and just loosening your bolts. Plus you can't go much lower then 3 or 4in in the front before you run into problems with the 4wd.
Old Oct 15, 2012 | 09:27 AM
04SSBlazer's Avatar
04SSBlazer is on a distinguished road
im getting mine installed in the next couple of day i back out the keys on my 04 and now im wiping of front end parts left and right i hope with the keys then rebuilding the front end/alignment it will stay good for a while i now gotta fight out what rims i wanna run
Old Oct 15, 2012 | 01:34 PM
NewbieT's Avatar
I got the ebay keys, like 40 shipped so half the price. Still running strong I did have to shave the torsion bar cuz it was to tight to get on one.
Old Oct 15, 2012 | 04:34 PM
neo71665's Avatar
The drop keys allows for more drop then just turning the bolts. If your gain is only an inch or so the factory parts work fine. You want more than 2 inches you have to have the drop keys. If you want 3 1/2 or more then you gonna have to convert the truck to 2wd by taking the front axles apart, running the outter stub in the spindle, and ditching everything else 4x4 related.
blazeofglory
Lowering Tech
Nov 1, 2013 12:50 AM
DrEaMsTeVe
Feb 15, 2011 02:50 PM
95Blzr
Jun 5, 2008 10:19 PM
ivannj
Jan 13, 2006 08:18 PM
9blzr9
Suspension Tech
Jan 10, 2006 12:10 AM
