Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
dropped blzr spring help
Old Oct 21, 2007 | 11:35 AM
agent305's Avatar
agent305 is an unknown quantity at this point
Default dropped blzr spring help
hi. when i got my truck last year i dropped it quite a bit..but the rear is still higher, and i want it to be even with the front
i need just about another inch but im layed off so i cant buy anything lol
but i heard you could take out one of the leafs in the leaf springs..
i just have 2 questions really....
(1) can someone show me which leaf to take out and how?
(2)is it really that safe to take a spring outs the leaf spring?
Old Mar 9, 2008 | 11:53 PM
drop's Avatar
drop is an unknown quantity at this point
Default RE: dropped blzr spring help
What type of drop do you have right now? There may be other things you can do.
You can pull the bottom leaf out. You unbolt it from the axle, undo the clamps, then undo the center bolt, the bottom one will fall off. Be careful of the load on the springs.
Old Mar 10, 2008 | 12:29 AM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
taking a leaf out can be unsafe for daily use.....
Old Mar 10, 2008 | 04:43 AM
thegr81's Avatar
Well at a lowered stance by now you should be use to avoiding holes and sewer covers in the road!!(at least I hope) Taking out the very bottom leaf will be fine, as long as you keep this in mind, slowly go over speed bumps and avoid all potholes and sewer covers as possible!! But on the other hand I have to ask what size drop block do you have in the rear???
Old Mar 22, 2008 | 03:39 PM
agent305's Avatar
its a 3" block in the rear.
so....it is the very BOTTOM leaf?
theyre not going to break if i remove it are they lol
i have to avoid everything when i drive, only cuz my rims stick out further than the tire.
Old Mar 22, 2008 | 05:13 PM
thegr81's Avatar
Well if you only want one more inch, then step up to a 4 inch tapered drop block I have that in the rear of mine!!! and I use all my leafs and factory shocks but if you can't track down or spend the money on them just take out the bottom most leaf and you will be fine and you wont ruin anything by doing that. People mono leaf the rear of mini's and ride like that for years with no problems!!
Old Mar 22, 2008 | 07:08 PM
agent305's Avatar
yea i was gonna get the 4" angled block...i found it online for like 25 bucks i think.
but here is the thing....
i have a 3" block in there now...and the rear shocks rub against the sway bar.
i thought if i got the 4" ones it would be worse
Old Mar 22, 2008 | 07:16 PM
thegr81's Avatar
Mine don't rub at all on my sway bar plus I left all my leafs in the rear!! Put it this way all I did to the rear of mine is add 4 inch tapered drop blocks thats it oh and the extended U bolts but thats it and I don't have any problems with the rear at all!! I will be cutting out my bump stops here soon and mono leafing the rear of mine to drop it lower till I can bag and 4 link the rear of mine!!
Old Mar 23, 2008 | 08:28 AM
agent305's Avatar
edit: i was gonna put my summer rims on this week, and was just wonderin if someone knew about how long it would take to remove the leaf from the leaf spring? if its a wicked pain ill just get the 4" blocks
your shocks arent hittin the sway bar? the rear of a 4x4 is the same as a 2 wheel drive isnt it?
i think im prolly just gonna get the 4" blocks.
but here is the deal....
another inch in the rear, my truck will sit even..
so im kinda confused on which way the angle of the block should go.
im sure ill figure it out when im actually under there tho
blaze21
Feb 21, 2011 08:04 PM
rabbit0102030
Lowering Tech
Mar 25, 2008 10:25 AM
88s10Blazer
Nov 6, 2007 07:57 AM
cody32401
Suspension Tech
Nov 12, 2006 02:28 AM
DaNK 305
Suspension Tech
Feb 26, 2006 09:27 PM
