Suspension Tech Have a question about modifying your suspension? Ask it here.
dropped
Old Nov 5, 2006 | 01:48 PM
cody32401's Avatar
cody32401 is an unknown quantity at this point
Default dropped
i dropped my blazer with a 3/3 groundforce drop well im happy with the front but the rear i would like to drop a little bit more should i just pull one of the leaf springs out or look for a bigger block?
Old Nov 5, 2006 | 01:58 PM
Blazin_Jason's Avatar
Default RE: dropped
I wouldn't remove a leaf personally. I think I read before that some trucks had 3 leaves, and some had 4. (Don't quote me on that though) Blazinlow.com would probably be your best bet to find out.
Old Nov 12, 2006 | 02:28 AM
00blackblazer's Avatar
00blackblazer is an unknown quantity at this point
Default RE: dropped
dont pull a leaf. also how much are you wanting to drop it? i see you went 3/3 groundforce. guessing 3 inch lowering springs and 3 inch block. you should have went all belltech 2 inch spindle in the front with the 2 or 3 inch spring. then in the rear you could have went with drop leafs 3 inches and either a 1 or 2 inch block angled of course to correct your pinion angle and also would have had to flip your rear brake lines.http://i96.photobucket.com/albums/l1...Picture005.jpg
chevcamls1
Suspension Tech
Apr 7, 2008 06:30 PM
rabbit0102030
Lowering Tech
Mar 25, 2008 10:25 AM
agent305
Lowering Tech
Mar 23, 2008 08:28 AM
88s10Blazer
Nov 6, 2007 07:57 AM
DaNK 305
Suspension Tech
Feb 26, 2006 09:27 PM
