Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
Ground Force Lowering Kit on 04 Blazer Xtreme
Old May 20, 2009 | 04:25 PM
Dready's Avatar
Dready is on a distinguished road
Default Ground Force Lowering Kit on 04 Blazer Xtreme ?'s
I want to use the Ground force lowering kit on my 2004 Blazer Xtreme
it has 3" springs and a 3" rear drop
I know since i have a Xtreme it will only lower it 1.5" up front.
My questions are...
Do you think the rear will be much lower than the front with the 3" drop?
Also..im pretty sure the 2dr blazer needs angle blocks in the rear..does the kist come with angle blocks or with flat blocks?
Also..will this kit work at all?
Thanks for all replies..im sorry i am a newbie..
And i know i should go with the 2" spindles upfront..but i dont want to pay $300+ for those
Old May 23, 2009 | 11:06 PM
Dready's Avatar
this sure is an active forum!
Old May 23, 2009 | 11:21 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
sorry i wasnt aware that we were here to wait on you hand and foot. buy the kit install it and call it a day. if your worried that the rear will sit to low the buy shorter blocks and it doesnt really matter if theyre angled or not. next time if your not satisfied with the amount of time it takes to get a response try running a search on your own all of this info has been discussed on the forum before.
Old May 6, 2011 | 10:26 AM
Dready's Avatar
I got the 3inch belltech springs and 3 inch angked blocks. The springs only lowered me and inch so I cut off a coil. It looked amazing but road like ***. The blocks did theiir job and lowered 3 inches. I've since got rid of my blazer mostly because it road like ***. If I were to do it again id save for the spindles.
eljorgin
May 21, 2019 10:04 PM
ghostriderjp
Aug 18, 2011 01:50 PM
hotrodclutch
Apr 25, 2011 03:25 PM
cide
May 1, 2009 01:07 PM
saggese820
Lowering Tech
Mar 29, 2009 08:48 PM
