Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
i want to get low!
Old Feb 10, 2010 | 12:51 AM
69ER's Avatar
69ER is on a distinguished road
Exclamation i want to get low!
im going to do the 3''-4'' kit and want to know if my leaf springs are gonna be an issue and also will i need to buy different shocks ????
Old Feb 10, 2010 | 01:04 AM
packofqtips's Avatar
packofqtips is an unknown quantity at this point
are you doing a spring/block drop?
or spindles springs leafs and blocks?
if you are doing blocks in the rear then stock shocks are okay, stiffer shocks would be better but you dont need shorter shocks, unless you use drop leafs
def get the drop shocks for the front though if you use springs
Old Feb 10, 2010 | 01:16 AM
69ER's Avatar
yeah i am going with the spring/block kit, cool so my leaf springs will be fine right, i was thinking they were gonna scrape?
Old Feb 10, 2010 | 01:17 AM
what size tires are you running?
Old Feb 10, 2010 | 01:21 AM
69ER's Avatar
16 inch iroc's
Old Feb 10, 2010 | 01:33 AM
should be okay
with a 50 series tire the mounting plate will be low but you should be okay
Old Feb 10, 2010 | 02:01 AM
69ER's Avatar
cool, thanx for all the help it was greatly appreciated.
mxboy96
Headers, Intake, & Exhaust
Jan 11, 2010 06:11 PM
DetroitMuscle
Dec 16, 2007 02:58 PM
prestigo
Tires and Wheels
Sep 19, 2007 07:49 PM
flowmasta
Aug 22, 2006 05:35 PM
Bojib
Dec 7, 2005 01:20 AM
