Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
lowering a 4wd
Old Oct 18, 2009 | 10:35 PM
  #21
Rebels01blazer's Avatar
Rebels01blazer is on a distinguished road
u can get the 3" or 4" blocks for the rear and keep your stock shocks in the rear you will have to cut your bump stops in the rear if you put the 4" blocks in the rear. If you back the torsion bolt out 8 full turns it will drop the front 3 inches if you buy the lowering torsion key you can drop 3"-6" in the front but you will have to remove your front cvs if you want to go further than 3 inches. yes in the front you will have to replace the front shocks when you drop more than 3" also. i have 3/4 currently but after my new keys come in it will be 6/7. and yes mine is a 4x4
Old Oct 18, 2009 | 10:40 PM
  #22
in my sig is the 3/4 with my 4wd still working.
Old Oct 19, 2009 | 02:40 PM
  #23
cloak01ls's Avatar
cloak01ls is an unknown quantity at this point
Good luck getting it aligned after a 6" front drop on Tbar suspensions...LMK how that goes...
Old Oct 30, 2010 | 10:00 PM
  #24
getmoney1576's Avatar
getmoney1576 is on a distinguished road
the keys will get it lower then 3"? i just unscrewed the torsion bolts cuz i figured i wuld get the same 3" drop as buying the keys...
and if you do drop it 6" and remove cv shaft you no longer have 4wd correct?
Old Nov 23, 2010 | 02:41 AM
  #25
Diablo1982's Avatar
Diablo1982 is on a distinguished road
pics?
Old Nov 25, 2010 | 12:54 AM
  #26
i tryed to attatch a pic not workin out so well
Old Nov 25, 2010 | 12:56 AM
  #27
oh i guess it did work not sure why its so small....
and that was after i first bought it its got clear corners painted grill removed bug guard and roof rack
Old Jan 19, 2011 | 10:53 AM
  #28
jdcharly_2's Avatar
jdcharly_2 is on a distinguished road
hi, i am from venezuela, i have a blazer ls 99 4x4 , some one speak spanish i need help about how low my blaze..
stevelknievel
Lowering Tech
28
Sep 27, 2008 07:54 AM
vagnozzi
Lowering Tech
May 12, 2008 12:52 AM
dbleon
Apr 9, 2008 12:30 AM
guitarman
Lowering Tech
Mar 16, 2008 12:29 PM
speeddemon560
Suspension Tech
Feb 6, 2007 04:18 PM
