Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
new guy needs tips.
Old Sep 18, 2012 | 11:29 PM
schongsxr1k's Avatar
schongsxr1k is on a distinguished road
Default new guy needs tips.
I just got a 2000 model 2wd 4door blue blazer. Love it so far. Was thinkin about puttin corvette grand sport 18x9.5 on it and lowering it. Any suggestions.
Old Sep 19, 2012 | 10:34 AM
tibby's Avatar
Default .
Be careful with wide wheels with high backspacing. I originally wanted to use 17x9 Camaro SS wheels with 6(somewhere around there) inches of backspacing and they gave me nothing but trouble. They hit frame when I turned, just too wide and I didn't want to get spacers.
So with an 18x9.5, check the backspacing. If it's high, you have no choice besides getting wheel spacers/wheel adapters if you want them to not rub.
Old Dec 14, 2012 | 05:58 PM
J_E's Avatar
J_E
J_E is on a distinguished road
You will not be abole to run Corvette or Camaro wheels on a 2wd S-series with out spacers. I don't remember the exact number but it will be at least 2.25", maybe 2.5". With the right spacers those wheels will clear with out issues.
Dropping it will be easy depending on how much low you want. You can do 1.5" with GM factory parts (Xtreme front coils and Xtreme blazer rear leafs). More low can be had with aftermarket parts. If you lower using springs, you will need shocks. If you use blocks, the stock shocks will still work for the back. I cannot say about lowering spindles except that they are costly.
Attnhor
Feb 2, 2011 03:50 AM
trukin55
Apr 16, 2010 05:37 PM
kymatt
Feb 11, 2010 09:57 AM
redeye202
Nov 18, 2009 03:34 PM
