Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
s10 Blazer rear springs?
Old Oct 1, 2012 | 08:46 PM
Chismall's Avatar
Chismall is on a distinguished road
Default s10 Blazer rear springs?
Hello I just bought a 1989 s10 blazer 2 wheel drive. I plan on lowering it 5/5, so I took a peek underneath the vehicle and noticed it has leaf springs plus shocks with a spring around it. Do all of these vehicles have rear shocks/springs? I was under the impression they just had leaf springs in the back.
My question is, how would I go about lowering the back with these springs and shocks in place? Can I just throw the blocks on there or do I need to do something different? Thanks.
Old Oct 1, 2012 | 09:10 PM
Blazin_Jason's Avatar
Shocks with a coil spring are definitely after market. I'm assuming they aren't an adjustable coil over setup.
Old Oct 2, 2012 | 12:39 AM
Chismall's Avatar
No they are not adjustable. So you say its aftermarket? If I go ahead and buy these blocks for the rear, should I just remove the shock/springs all together? I'm assuming I would need to, I would think they would get in the way of lowering...
Old Oct 3, 2012 | 08:34 PM
duxtoyz's Avatar
duxtoyz is on a distinguished road
those shocks with springs on them are just for better load handling. ul need to remove them in order to lower ur truck, but i would recommend getting sum smaller shocks to replace those cause itl ride real ****ty if u dont. just leaf springs will be way bouncy. u can find lowered truck shocks all over the net for cheap too. check ebay or ur local parts store.
bang4dabuck
Nov 17, 2010 09:34 AM
S10Blazerdude
Lowering Tech
May 1, 2010 07:56 PM
doodad69
Dec 5, 2008 08:48 AM
lennyblazer
Jul 6, 2007 11:10 PM
