Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
t-bar question
Old Sep 19, 2009 | 08:06 PM
VortecSS's Avatar
VortecSS is on a distinguished road
Default t-bar question
hey i lowered my blazer with the torsion keys. what are the risks with doing this? how low can i go with doing this?
Old Sep 19, 2009 | 10:57 PM
mdehoogh's Avatar
Get an alignment as soon as you can. The torsion bar adjusters are there precisely for that purpose, to adjust (raise or lower) ride height. When lifting, the angle of the CV joints is increased which generate more friction. Friction = heat, and heat = wasted power. When lowering, the CV axles actually line up straighter which reduces friction and wear.
Make sure the rubber boots around the CV joints are seated properly. Changing the position of the joints can cause the rubber boots to leak grease.
There should be no long-term effects from lowering like you did. Also, there really is no other (easily reversible) way to lower a 4x4 s-truck.
Again, get an alignment. If you leave it as is, the outer edges of your front tires could wear out much quicker than usual
Old Sep 20, 2009 | 11:06 AM
VortecSS's Avatar
thank you
sparty992
Jan 23, 2012 08:08 PM
texas rebal
Dec 6, 2011 11:01 PM
btmbass
Mar 28, 2011 11:31 PM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
