Thinking about lowering
I have been thinking of lowering my blazer instead of lifting it I already know that I can so the t bar method and get some drop on the front and I can get 3" of drop with leaf springs in the back but how do I get even more drop in the front I was thinking it would be shorter coil springs but I have no knowledge lowering vehicles btw it is a 4wd
You don't have coil springs up front. The torsion bars are your "springs" so you can really only lower it as much as the torsion bar bolts will allow. Removing them completely will net you nearly 2 inches, I believe. Anything more than that and you're looking at cutting and welding and whatnot.
Lowering blocks
you unbolt the rear end and put the blocks on top of the leafs then put the rear above the lowering block
walah you have lowered the rear of your blazer
Edit: here is a pic its sorta small but possible to see
http://www.cardomain.com/ride/3921170/1996-chevrolet-s10-blazer#39211704022
Edit:2 Here we go i found a better picture for you
http://www.1969fb.com/pics/1954picku...0Installed.jpg
Seems like to much damn work lol I will probably just do the belltech 3" drop leaf springs in the rear and just lower the t bars as far as they will go in the front considering I don't want to bag it or anything just want to give it a better stance and on another thread I started I asked how far I can back the bolts out on the t bars and someone said I can take them completely out is that true? if I take them out what supports them and keeps them from moving? just curious because my wife tells me that people are just lying to me so I ruin my Blazer so can someone give me some solid info so I can convince her to take the bolts all the way out.
I dont know how it would react if you remove them completely but the ride quality will change i know that
and putting the blocks is way easyer and cheaper then getting lowering springs but thats my opinion
blocks is cheaper too
I believe it was me who said you can take hte bolts out, and it's completely true. I did it on my 94. All the bolts do is adjust how much tension is on the torsion bars. With the bolts removed, the bars have very little tension, therefore the truck is lower. You are not at all changing how the bars are mounted, only how much pressure or twist is on them.
I'll look around and see if I have any pictures of the front end of my 94 after I did this to it. The one thing you'll need to do is get an alignment IMMEDIATELY after changing anything with the torsion bolts. You jack up the alignment every time you adjust them, so have it aligned once you do whatever it is you are going to do with that otherwise you can and probably will ruin your truck.
All that said, I'm wondering if your wifes objection is less about doing this and more about not modding a perfectly good daily driver? A lot of people would prefer a car stay stock in the belief that it makes it "more reliable." I'd talk it out with her carefully and respectfully before doing anything.
