Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
Thinking about lowering
Old Dec 22, 2011 | 09:14 PM
  #21
89Recon's Avatar
89Recon is an unknown quantity at this point
So all in all it IS safe to remove the bolt completely now I have a drawing I can show to my wife lol
only difference on mine is the piece where the bolt comes out of is sideways not lengthwise like in the photo is that an issue ? or is that just because it is a 1st gen ?
Last edited by swartlkk; Dec 22, 2011 at 09:19 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond. Rules are rules.
Old Dec 22, 2011 | 10:04 PM
  #22
mdehoogh's Avatar
What piece, the block or the bolt itself? If the block is just situated differently there shouldn't be a problem. The bolt should be vertical regardless of 1st or 2nd gen. If it's not then there might be a problem...
If you can snap a picture we could tell you for sure.
Old Dec 22, 2011 | 10:10 PM
  #23
89Recon's Avatar
the block piece not the actual bolt the bolt is vertical with just a slight angle to it but nothing drastic
Old Dec 22, 2011 | 10:11 PM
  #24
xgiovannix12's Avatar
thats normal
Old Dec 22, 2011 | 10:17 PM
  #25
89Recon's Avatar
good to know and one more question could my height difference in both sides be due to one of my t bars being weaker than the other or could it be my one leaf spring that is busted ?
Old Dec 23, 2011 | 08:39 AM
  #26
TheRandom1's Avatar
Could be both.
Old Dec 23, 2011 | 12:07 PM
  #27
89Recon's Avatar
so by replacing the leaf springs it could still be off on one side ? also to correct the difference can one torsion bar bolt be taken completely out and the other one just adjusted to match ?
Old May 7, 2012 | 09:48 PM
  #28
Shawn Squeeks Whitfield's Avatar
Shawn Squeeks Whitfield is on a distinguished road
has anybody ever tried taking the superlift 2"lift upper control arms flipping them over switching sides then installing to get the alignment in place. it would probably help with sront suspension wear also
Old Jul 13, 2012 | 08:38 PM
  #29
mud_yeti87's Avatar
mud_yeti87 is on a distinguished road
bump! would really like to here someones opinion on flipping and swaping UCA's. i used to have a nissan hardbody that was a torsion bar truck and i know you could do that with the stock UCA's to help reduce balljoint strain and reduce negative camber. would REALLy like to know if it could be/has been done on sec gen 4x4's
04SSBlazer
Tires and Wheels
Apr 10, 2013 10:09 AM
kontrix
Lowering Tech
Nov 8, 2012 01:12 PM
1994BlazerS10
Nov 29, 2009 07:22 AM
ivannj
Engine & Internal
Jan 20, 2006 10:52 PM
Dodge Guy
Jun 28, 2005 02:04 AM
