Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
want to lower, but confused
Old Sep 21, 2008 | 06:59 AM
trafik's Avatar
trafik is an unknown quantity at this point
Default want to lower, but confused
ok, i have an 89 s10 blazer 4.3l 2wd, and i want to lower it with a little bit of wheel tuck(17's or 18's). i've tried searching, but have no clue wut all these numbers n stuff are. so i need help on which suspension products to buy to obtain this height. i'm currently running the stock 15's. wut will i need or shall i say how low do i go in the front, and how low do i go in the back? i see belltech 3/3 kits, but will that be enough, or can i buy other things with it to make it lower? I NEED ANY HELP I CAN GET... THANK YOU...lol i could also use a tutor, i just came out of the import world, i just couldnt pass up on the blazer i found.
Old Sep 21, 2008 | 07:28 PM
nj4x4blaze's Avatar
Default RE: want to lower, but confused
If you wanna go lower than a 3/3 drop I would suggest looking into bagging your truck if it's 2wd. Requires alot of work, but done right you can lay frame.
Old Sep 21, 2008 | 11:42 PM
blazin97's Avatar
blazin97 is on a distinguished road
Yah the only way to tuck 17's or 18's you need to bag it. Your looking at around 3-5 grand to have a shop do that for you.
Old Sep 22, 2008 | 02:59 AM
trafik's Avatar
well then how low can i go without having to bag it? wut will the fender gap be?
Old Sep 22, 2008 | 02:07 PM
2drbucket's Avatar
2drbucket is an unknown quantity at this point
It will take a combination of measurements to obtain the info your looking for.
Old Sep 23, 2008 | 04:15 PM
blazin97's Avatar
in my sig is my 97 2wd it has 18's with a 2/3 drop.
Old Sep 26, 2008 | 03:33 AM
trafik's Avatar
i didnt even think it was lowered at first. how much did it cost you? and wut did you use?
Old Sep 26, 2008 | 01:59 PM
blazin97's Avatar
cost about $80 because I bought the 2" spindles from a member on here for CHEAP and 3" blocks.
IMO spindles are the best way to go, and you can pick them up new for $150 plus about $30 for blocks. If you use front springs then dont forget bout the alignment you will need afterword(spindles you dont have to).
Old Sep 27, 2008 | 02:59 AM
packofqtips's Avatar
packofqtips is an unknown quantity at this point
you need an alingment even with spindles anytime you take the front end apart you need an alignment
newguy
Oct 31, 2012 12:15 AM
ocfvbadboy
Lowering Tech
Nov 11, 2011 03:49 AM
nobody500
Lowering Tech
Oct 7, 2009 07:33 PM
cameronp29
Lowering Tech
Sep 27, 2007 08:57 PM
boomtruck97
Suspension Tech
Sep 8, 2006 02:56 PM
