want to lower, but confused
ok, i have an 89 s10 blazer 4.3l 2wd, and i want to lower it with a little bit of wheel tuck(17's or 18's). i've tried searching, but have no clue wut all these numbers n stuff are. so i need help on which suspension products to buy to obtain this height. i'm currently running the stock 15's. wut will i need or shall i say how low do i go in the front, and how low do i go in the back? i see belltech 3/3 kits, but will that be enough, or can i buy other things with it to make it lower? I NEED ANY HELP I CAN GET... THANK YOU...lol i could also use a tutor, i just came out of the import world, i just couldnt pass up on the blazer i found.
If you wanna go lower than a 3/3 drop I would suggest looking into bagging your truck if it's 2wd. Requires alot of work, but done right you can lay frame.
cost about $80 because I bought the 2" spindles from a member on here for CHEAP and 3" blocks.
IMO spindles are the best way to go, and you can pick them up new for $150 plus about $30 for blocks. If you use front springs then dont forget bout the alignment you will need afterword(spindles you dont have to).
ocfvbadboy
Lowering Tech
Nov 11, 2011 03:49 AM
