whats the most common?
whats the most common drop for a '02 blazer 2dr LS 2WD? & whats the best way to tell how low its been dropped in the front? im new to this blazer forum thing so it be great if some1 would help me out?
ok so if i got 3 inch blocks out back then i must have a 2 inch drop up front cuz it does sit even. well let me ask this...can i use a factory size shocks with the 3 inch blocks out back? or do i need drop shocks?
when you use drop blocks in the rear it doesn't change the distance the rear shocks travel therefore stock shocks are fine
if you use leafs in the rear then you would need drop shocks because you have shortened the distance of the shocks travel
Based on this principle, you'd be fine with stock shocks and spindles in the front I'm guessing? Or am I full of bull-oney? lol... The shocks mount to the front IFS arms am I correct? Meaning if you backed off the T-bars to get your drop, you'd probably want the shocks since the distance between the shock mounting points is changing.
