A/C Works great until engine heats up. Blows warm and feet are hot too
Old Aug 28, 2024 | 04:35 PM
Oz_USAF_Retired's Avatar
Oz_USAF_Retired is on a distinguished road
Default A/C Works great until engine heats up. Blows warm and feet are hot too
Hi there, I'm new at this forum. I took my vehicle to a local Chevy Dealer to look at my A/C issue. The gentleman said it either works or doesn't. I said it sometimes works and sometimes it doesn't. Made me feel like a moron until I started reading up on it. I need to know where I should start with the triage. Easiest to hardest/priciest. Can anyone help? 2001 Chevy Blazer, 4 door, 4.3, 4x4, LS.
Old Aug 29, 2024 | 10:19 AM
GeorgeLG's Avatar
Please describe the problem in more detail. What doesnt work? No blower fan, blows hot, compressor does not start, compressor struggles, etc.
George
Old Aug 29, 2024 | 10:38 AM
George
George, I start my Blazer and turn AC on, works like a champ. Once the vehicle temperature gauge gets close to 210, I think (the sweet spot for the vehicle temperature), the AC starts to warm up and I start to feel my feet starting to warm up. My thought is, the AC and heater are running at the same time. Is that possible? Does that explain my issue well? I really appreciate your help and feedback.
Old Aug 29, 2024 | 10:46 AM
GeorgeLG's Avatar
When it starts to warm up is the compressor still on or at least cycling? Is the refrigerant line still cold and sweating near the accumulator? Check that line when everything is working for reference.
Warm can be a failure of the refrigerant circuit (low gas, compressor, cap tube , plugged condensor, etc) or the control system in the dash (vacuum and electric operated controls, solenoids or doors). One example of the latter would be a failing blend door allowing full heat with a call for AC,
George
Old Aug 29, 2024 | 12:44 PM
Warm can be a failure of the refrigerant circuit (low gas, compressor, cap tube , plugged condensor, etc) or the control system in the dash (vacuum and electric operated controls, solenoids or doors). One example of the latter would be a failing blend or allowing full heat with a call for AC,
George
George, thanks for the quick response. I will test those you mentioned and post here
Old Aug 29, 2024 | 01:07 PM
GeorgeLG's Avatar
NP. Thats blend door BTW, I corrected my post.
George
ondine
Jan 29, 2019 09:15 PM
abohanon
Aug 30, 2011 03:33 PM
Stablock
May 16, 2011 12:38 PM
scoot
Mar 14, 2007 12:41 AM
