Combining suspension and body lift?
Old Aug 17, 2024 | 02:29 PM
SeanC's Avatar
SeanC is on a distinguished road
Default Combining suspension and body lift?
Hey guys, a new member here. I have a 2002 LS 4x4 Blazer, 5-speed manual. I recently added a custom hood with 2" spacers and a 2" suspension lift. I'd like to add a body lift to bring up the rear a couple more inches. Has anyone combined a suspension lift and a body lift? How'd it work out for you?
Old Aug 18, 2024 | 03:15 PM
AJBert's Avatar
It would be cheaper and easier to put in 2" lift shackles than a body lift. And if you do put in a body lift, you will still have the infamous saggy rear end these Blazers/Jimmy's are famous for.
Old Aug 18, 2024 | 06:36 PM
SeanC's Avatar
I had 2" shackles installed and it did help with the saggy rear end but still not satisfied. Good to know I can add a body lift and get some more height back there. Thanks.
Old Aug 19, 2024 | 09:34 AM
El_Beautor's Avatar
If you're looking to address the saggy rear end you'd probably be better off going with either new or re-arched springs, or with an add-a-leaf.
If you go with an add-a-leaf the best results would be to find a used leaf pack, and use the main leaf with the eyes cut off the end so that it supports the whole length of your factory main leaf. I found (as did others) that the add-a-leaf kits you can buy helped, but they weren't long enough so the main leaf tended to just start sagging past the un-supported section and you end up with a 'W' shaped main leaf.
Old Aug 25, 2024 | 10:47 AM
You can't put a body lift just on the rear, so you would still have the same problem of it sitting lower in the back. You could always put the axle under the springs, but that would give you something like 5" of lift, just in the rear. Maybe if you took out the add-a-leaf and the lift shackles...
Old Aug 30, 2024 | 05:41 PM
SeanC's Avatar
Appreciate the feedback guys. I'm gonna look into axle under springs idea. I think back end could handle 5" and look pretty sick. Front end already has a 3" lift. Thanks fellas.
Deo Duncan
Suspension Tech
Mar 18, 2017 06:58 PM
01blazer16
Lifting Tech
Jun 27, 2013 06:04 PM
wlorton
Lifting Tech
16
Dec 26, 2009 05:05 PM
<3blazer
Suspension Tech
Jun 13, 2009 09:32 PM
94camaro
Lifting Tech
Dec 15, 2008 08:45 PM
