Nitrous, Super Chargers, & Turbos All charged talk about going FAST.
Banks Turbo and Stock Exhaust
Old Oct 3, 2010 | 08:20 PM
mafiaboy01's Avatar
mafiaboy01 is on a distinguished road
Default Banks Turbo and Stock Exhaust
Hi, I purchased a used banks turbo kit for my 87 Chevy Blazer with a 6.2L Diesel
It's old and rusted but it still in good shape. I have to change the gasket between the two half's of the turbo and some rust removal.
But my main concern is that the banks kit came with a 3 inch exhaust and their muffler.
This however was not included in my purchase.
Now I am wondering if it would be ok to connect the 2 inch stock exhaust into the turbo?
If not was is my cheapest alternative.
Old Oct 3, 2010 | 08:37 PM
wlorton's Avatar
I am not necessarily the best source, but being that you are using air from a 2inch exhaust to run the turbo shouldnt make too much of a difference, because it is exhaust driven.... But I could be completely missing the idea..... I know that a smaller pipe will cause more friction/size than a larger one.......
Old Oct 3, 2010 | 08:39 PM
mafiaboy01's Avatar
My only concern is that it would cause a lot of back pressure as its not as easy flowing as the original banks exhaust is.
I just don't want to damage the turbo with all the back pressure.
Old Oct 3, 2010 | 08:44 PM
wlorton's Avatar
Don't Quote me, but the backpressure drives the turbo, and you put a blow off valve on the other side because the pressure on the air intake side can damage the engine.... Turbos are made to be thrown pressure at ... I believe...
Old Oct 4, 2010 | 06:45 AM
I wouldn't run a 2" pipe where the original was 3". You want to keep restriction before the turbo to a minimum. I would recommend you have a 3" pipe made up to run to the turbo.
Old Oct 4, 2010 | 07:20 AM
96Blazernut's Avatar
96Blazernut is an unknown quantity at this point
You can run the stock exhaust with the kit, however you won't realize it's full potential until you upgrade the exhaust. And you dont need a blow off valve because diesels do not have a throttle plate. Blow off valves are used on gasoline engines where you want to keep the turbo rpm's up. I had one on my Conquest which had a turbo on it.
Old Oct 4, 2010 | 10:52 AM
mafiaboy01's Avatar
Probably just gonna hook it up like this for now then switch it when i hey some more money. I was also thinking of taking out the muffler and that should give enough flow.
mafiaboy01
Headers, Intake, & Exhaust
Apr 26, 2011 11:20 AM
mafiaboy01
16
Oct 24, 2010 07:16 PM
hpb182
Jun 21, 2010 11:24 PM
quebecoffroad
Aug 24, 2007 08:46 PM
