Nitrous, Super Chargers, & Turbos All charged talk about going FAST.
Nitrous and High Octane?
Old Jun 26, 2005 | 06:15 PM
02 Vortech's Avatar
02 Vortech is an unknown quantity at this point
Default Nitrous and High Octane?
hey yall i was wondering they said on some website that you have to use high octane fuel when running nitrous oxide to keep from having detonation or melting the engine, i would like to know, is this true.
Old Jun 27, 2005 | 12:04 AM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
Default RE: Nitrous and High Octane?
thats what ive heard too.
Old Jun 27, 2005 | 03:03 AM
LoLoS10Blazer87's Avatar
LoLoS10Blazer87 is an unknown quantity at this point
Any power adder is going to make the engine work harder, the lower the octane, the more chance of detonation. Detonation = uh oh. I don't know 'bout y'all, but 93 is as high as we go here. When I get my Supra running right I'm gonna use 93 but with a couple gallons of 110 from the local speed shop.
But yeah, basically when you add power, higher octane fuel is a must
Old Jun 27, 2005 | 03:27 PM
02 Vortech's Avatar
thanks for the info , but do any of you know how to set up an auxilary fuel cell system because if you could tell me the components it would be much appreciated..
Old Jun 27, 2005 | 04:54 PM
Patrick's Avatar
Patrick has disabled reputation
you dont want to EVER run any low grade fuel..i have a zex 55-75 shot, and if youre going to run nitrous, it is counteractive to run crappy fuel. the oxygen that you breath contains molecules that make up everything, and the air, is one part oxygen, and the rest is whatever else is floating around. nitrous is two parts oxygen, so its like double the oxygen in the same amoutn of space, bonded together by one atom of nitrogen the nitrogen is what hold sghe oxygen together, and when it enters the engine, that molecular compound breaks down, and the 2 atoms of oxygen are released, and expand. causing a hotter burn due to increased chamber compression. the added oxygen also allows for a more efficient combustion. putting low octane gas doesnt make sense because the nitrous is increasing your engines need to octane, and by putting low grade gas, youre starving the engine, and thus limiting the usefulness of the nitrous.
chris015
Nov 23, 2011 10:11 AM
88s10Blazer
Engine & Internal
Jun 23, 2006 01:39 AM
BlaZeR FXB1581
Engine & Internal
May 31, 2006 04:16 PM
02 Vortech
20
Feb 17, 2006 05:06 PM
ivannj
Feb 11, 2006 05:38 PM
