2.5 rough country lift
Old Jul 29, 2022 | 09:20 PM
DifferentCandy's Avatar
DifferentCandy is on a distinguished road
Default 2.5 rough country lift
I installed the 2.5 in lift im wondering if i should upgrade to the ZR2 axles
Old Jul 29, 2022 | 09:40 PM
If you go into my build thread, I as many others, have installed the rear axle from zr2s. I was lucky enough to get a cast iron front diff aswell... I put new seals on, while installing, 3.72 gear really make the lift and bigger tires better... really enjoy them! You will not be disappointed.
Old Jul 29, 2022 | 10:55 PM
i guess i should have specified im wondering about the fronts almost seams like the front axles are a little short now im wondering if the ZR2 are longer
Old Jul 30, 2022 | 02:58 PM
Yes the front cv axles are longer in the zr2
Old Jul 30, 2022 | 04:30 PM
thank you
Old Jul 31, 2022 | 09:12 AM
Np. Nice ride btw... any other plans with her?
Old Aug 5, 2022 | 01:02 PM
just LSD in the rear and eventually im going to go with the 6in lift and 35s full SAS
Old Aug 15, 2022 | 01:10 PM
El_Beautor's Avatar
Just to chip in to clarify, while you can swap the wider ZR2 rear axle, the front diff is physically identical (other than the rare iron case from a manual transmission ZR2). The main reason to swap the front diff is if your existing front diff has a different gear ratio from the ZR2 donor. You cannot swap the longer ZR2 CV axles into a normal Blazer to make it wider. They won't fit. The extra front width on the ZR2 comes from frame differences and wider mounting points for the control arms.
Old Aug 19, 2022 | 08:08 PM
thanks man thats what i was wondering
Irocz327
Jul 19, 2015 06:38 PM
01blazer16
Lifting Tech
Jun 14, 2013 04:49 PM
Dbam31
Sep 10, 2010 04:24 PM
nit8690
Lifting Tech
May 18, 2010 05:39 PM
mudsliner
Lifting Tech
May 12, 2007 06:17 PM
