bfg 31x10.50 HELP!!!!
Old Sep 6, 2007 | 10:52 PM
skimorebutts's Avatar
skimorebutts is an unknown quantity at this point
Default bfg 31x10.50 HELP!!!!
k heres the deal i would like to buy some muddin tires from a buddy they are b f goodrich all terrain t/a 31x10.50 i would like to know if there is any chance of them fitting on my 91' s10 blazer 2 door and or what are my options.
plz help!!! thanx
Old Sep 6, 2007 | 11:58 PM
Shizer's Avatar
Shizer is an unknown quantity at this point
Default RE: bfg 31x10.50 HELP!!!!
I have 33.10.50s in the back and 33.9.50s in the front and no lift. Only problem is with mine is rubbing wail turning. I would say 31s would do fine.
Old Sep 7, 2007 | 11:12 AM
RCars2's Avatar
RCars2 is an unknown quantity at this point
They will fit but they will rub at full lock like shizer said. Hanr3 knows someone with a 1st gen blazer (pre95')and i think he said that had 31's on it and it rubbed a bit at the top of the fenderwhen going offroad hittingmost bumps. If its anything similiar to the2nd gens (95' and up), you will rub quite a bit if you plan on driving over any moderate to large bumps, including most speed humps if you hit them too fast. The solution, some sort of lift. I reccomend body lifts as they are fairly easy to install and they dont destroy the driving characteristics of the truck or put any stress on the front end components. Now your other option is going with a torsion bar crank and shackles. BE FORWARNED this will cause front end wear as you are putting you cv's and ball joint's in more steep angles. Its cheap and easy to do though and if you feel comfortable doing this and know what to watch for in terms of wear you can go this route. Myself i actually have both the body lift and the torsion bar crankand i run it as a daily driver. Its been ok so far but i have had to replace both cv's and all 4 ball joints.
Old Sep 12, 2007 | 12:56 PM
Hanr3's Avatar
Above is mostly correct. They rub the back of the front fender.
2" body lift the most economical way of fitting 31" tires under your truck.
ImScrewed92
Tires and Wheels
18
Jan 21, 2010 11:19 AM
Nazdreg
Tires and Wheels
Apr 5, 2008 11:24 PM
rickyp3278
Tires and Wheels
Mar 22, 2008 10:06 AM
krkline2gdsm
Tires and Wheels
Oct 29, 2007 10:41 PM
Taymacjack
Tires and Wheels
Aug 22, 2007 06:33 PM
