31x10.5x15 fit?
Old Oct 28, 2007 | 07:54 PM
krkline2gdsm's Avatar
krkline2gdsm is an unknown quantity at this point
Default 31x10.5x15 fit?
stock suspension, stock 15" rims, no lift, nothing!
Found a nice deal on goodyear wrangler APTs 31x10.5x15 for cheap cheap cheap! I am going to buy them and put them on regardless. Going to buy some spacers too. Anything I should do before mounting these things?
Old Oct 28, 2007 | 08:00 PM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
Default RE: 31x10.5x15 fit?
may need to remove the bottom fender bolt behind the tire on the front fenders. a set of 2wd rims would help also, it will set them out about 2' more than stock
Old Oct 28, 2007 | 09:53 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
31's will not fit without major rubbing on a stock suspension. You will need to lift at least 2" to stop the body from rubbing and may need tolift the suspension some to stop frame rubbing. The most you should be able to fit is 30's.
Old Oct 29, 2007 | 05:35 PM
RCars2's Avatar
RCars2 is an unknown quantity at this point
The exception to the rule of course is if you have a ZR2 as many of those have 31's from the factory. To keep from rubbin, crank your tbars as a minimum and get add-a-leafs or shackles when you can or get a body lift. With that you should be good for the most part, big bumps might present some issues but nothing major.
Old Oct 29, 2007 | 10:41 PM
Jigg's Avatar
Jigg is an unknown quantity at this point
And ZM6's. I ran 31's on my stock ZM6 with only minor offroad rubbing.
2wd rims will only make the rubbing worse. Stock rimsare the way to go to eliminate rubbing.
fletch125
Mar 27, 2014 11:57 PM
heeb2424
Lifting Tech
43
Feb 8, 2012 06:40 PM
blazinhigh98
Tires and Wheels
Sep 5, 2011 03:35 PM
greatwhite
Tires and Wheels
Jan 4, 2011 11:36 PM
RebelJimmy96
Tires and Wheels
Dec 4, 2009 05:52 PM
