Discreet front receiver?
Old Apr 19, 2010 | 04:21 AM
KD5NRH's Avatar
KD5NRH is on a distinguished road
Default Discreet front receiver?
99 4door, 2WD. I don't do a lot of heavy offroading, but I do have some land that I've been working on, and since I'm usually out there alone, getting stuck would be a real pain. What I'd like to do is put 2" receivers and wiring for a winch on both ends. Texas requires an unobstructed front license plate, and going below the stock plate mount would put the receiver/winch too low for my taste. Ideal would be some way to mount a receiver about where the front plate is now, and use one of the receiver-mount license plate brackets when I don't have the winch there.
What's available ready-made for this model, and what have people rigged up?
Old Apr 19, 2010 | 09:34 AM
abig84's Avatar
They sell a set uo for the fullsizes where the hitch is flush with the bottom of the bumper and the inch sits on a tray. So it'll sit just about here the plate is
Old Apr 19, 2010 | 09:50 AM
jdespain's Avatar
I have recently aquired a reciever hitch from a local salvage yard from who knows what that I am in mid-process of (when I can find time to get to my Dad's house where the welder is) modifying it to bolt directly to where my tow hooks were and still sit flush with the bottom of the bumper. I can not use my hooks anymore since the body lift and installation of the bull-bar. Just an idea that I'm working on.
Old May 5, 2010 | 08:00 PM
rush1329's Avatar
rush1329 is an unknown quantity at this point
check these out man, mount where the tow hooks are like jdespain said... and check out the d-ring shackles also
http://shop.synergyoffroad.com/S-Ser...-RcvrTubes.htm
http://shop.synergyoffroad.com/Rampa...le-RAM8610.htm
Old May 5, 2010 | 10:41 PM
oktain's Avatar
Well... if you're only using this when you're offroad, why not set up a receiver behind the plate with a flip down mount? Cut a hole in the air dam behind the plate and set up your hitch so it's flush with the air dam.
When you need a reciever, or that D-ring you just flip the plate down and slide it in...
Sort of the same way that guys put hitches on their trucks with roll pans... just in the front.
Old May 7, 2010 | 02:44 PM
rush1329's Avatar
excellent idea oktain, however that could cause a problem if you live in a state like NJ, where the plate must be visible at all times, both front and back.. obviously every state is different but just somethin to keep in mind... i like the idea though!
Old May 7, 2010 | 04:28 PM
HcHawks09's Avatar
Well... if you're only using this when you're offroad...
I dont think your Truck has to be street legal...when its not actually on the street lol
but again, evey state is different.
That would def be the route I would go though.
Old May 7, 2010 | 08:41 PM
R3MiX's Avatar
R3MiX is on a distinguished road
I mounted a hitch in the front of my ford. Basically what I did was take an existing rear hitch, and cut it down to fit between the frame rails, then set it in place, notched out the bumper slightly, and welded the sucker in. Sturdy as a rock. I'll get a pic of it when my gf gets back with the truck.
EDIT: Shes home, pics are up. It's not super discreet, but with some slight modifications, it will work. And I live in texas also, it meets all laws.
packrat1969
Jul 19, 2012 07:06 AM
tibby
Jan 31, 2012 09:32 AM
cherokee4
Jul 23, 2011 03:42 PM
ack
Feb 11, 2008 06:15 PM
Mr Blazer LT
Sep 28, 2007 05:19 PM
