My Rear
Old Sep 18, 2007 | 03:05 AM
TheBrettster's Avatar
TheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond repute
Default My Rear
Can anyone tell me what rear end i have (gears) I'm going to be getting into 4x4'n and i need to know what i should upgrade.
Old Sep 18, 2007 | 03:58 AM
drperry's Avatar
Default RE: My Rear
The GU6 show's that you've got 3.42 gearing in your diffs...
However, you have an open diff, so you'll probably be doing a lot of spinning...
Old Sep 18, 2007 | 04:15 AM
Taymacjack's Avatar
Default RE: My Rear
AJ1 WINDOW TINTED , "DEEP, ALL EXCEPT W/S AND DRS"
AN3 SEAT , "FRT, INDIVIDUAL (NON BKT)"
AP9 NET , CONVENIENCE
AU0 "LOCK CONTROL, ENTRY" , REMOTE ENTRY
AU3 LOCK CONTROL , "SIDE DR, ELEC"
AXP VIN IDENT , "POSITION, MULTI-PURPOSE VEHICLE"
A31 WINDOW , "POWER OPERATED, ALL DOORS"
BQ2 FLEET INCENTIVE , AVIS CORP (C/D/E/F/G/H/J/K/L/N/M/U/W/Z-TRK
B30 COVERING FLOOR , CARPET
B84 MOLDING B/S , EXTERIOR
C25 WIPER SYSTEM , "RR WINDOW, INTERMITTENT"
C3T GVW RATING , "5,350 LBS"
C49 DEFOGGER , "RR WINDOW, ELECTRIC"
C60 HVAC SYSTEM , "AIR CONDITIONER FRT, MAN CONTROLS"
DAY PLANT CODE , "MORAINE, OH, USA"
DH6 MIRROR I/S FRT VAN , "LH & RH, SUNSHADE, ILLUM"
DK2 MIRROR O/S , "LH & RH, REMOTE CONTROL, ELECTRIC, HEATED,"
DK7 CONSOLE ROOF , "INTERIOR, CUSTOM"
D55 CONSOLE , "FRT COMPT, FLOOR"
D96 STRIPE , BODY SIDE UPPER
EVA TEST , "DVT, EVAP EMISSION REQUIREMENT"
FF5 ARM RH , TORS BAR SPRING ADJ (D)
FK2 ARM LH , TORS BAR SPRING ADJ (A)
FLT SALES PROCESSING , OPTION
GU6 AXLE REAR , 3.42 RATIO
JC1 BRAKE , "VAC POWER, 4 WHL DISC, 5,500 LBS"
K18 REACTOR SYSTEM , "AIR INJECTION, ELECTRIC"
K34 CRUISE CONTROL , "AUTOMATIC, ELECTRONIC"
K60 GENERATOR , 100 AMP
L35 ENGINE , "GAS, 6 CYL, 4.3L, CPI, V6, 90 DEG, HO"
M30 TRANSMISSION , "AUTO 4 SPD, HMD, 4L60-E, ELECTRONIC"
NC1 EMISSION SYSTEM , "CALIFORNIA, LEV (NOTE:"
NP5 STEERING WHEEL , LEATHER WRAPPED
NP8 TRANSFER CASE , "ACTIVE, TWO SPEED, PUSH BUTTON CONTROL"
N33 STEERING COLUMN , TILT TYPE
N40 STEERING , "POWER,"
N90 [IMG]http://www.s10forum.c
Old Sep 18, 2007 | 04:54 AM
Default RE: My Rear
Wow thanks tay, is having those gears and advantage or something i should replace. I'm looking for perfomace on the road and on the dirt.
Old Sep 18, 2007 | 05:43 AM
drperry's Avatar
Default RE: My Rear
They're kind of a mid-range gear...
Fairly decent acceleration, while still getting good mileage, due to lower RPM's on the highway...
I wouldn't worry too much about the gears until you either, go to get deep into the 1/4 mile, or get into 34" or larger tires...
Personal preference might make you want to switch to 3.73's with the larger tires, or possibly even 4.10s...
Even with the 30" tires, I can still squawk the tires shifting into 2nd gear, on clean, dry pavement...
I wouldn't reccomend gears any higher than 3.73's if it's a daily driver, unless you switch to 32" or larger tires...
I don't plan on changing my gearing, because I plan on dropping in a V8, so I'll have the oomph to turn the tires... since I also plan on eventually getting a 6" lift, 2" body lift, and running 34s... or possibly modding it even further for 35s or the ever elusive 38" ers, lol.
For 4x4ing with 32" or less tires, I don't think you'll have a problem turning them at all... At least, nothing that 4lo won't fix, lol.
Old Sep 18, 2007 | 11:38 AM
Default RE: My Rear
ORIGINAL: drperry
We wont go there, that seems to break my motor mounts .
Old Sep 18, 2007 | 12:35 PM
RCars2's Avatar
RCars2 is an unknown quantity at this point
Default RE: My Rear
ORIGINAL: TheBrettster
ORIGINAL: drperry
ROFL!!!!! So im not the only one who had that problem.
Old Sep 18, 2007 | 12:48 PM
rriddle3's Avatar
Default RE: My Rear
Oh, man! I saw the title of the thread, got all excited, and then realized it's from a dude.[:'(]
Thanks a lot, Brett! [:@]
Old Sep 18, 2007 | 03:18 PM
drperry's Avatar
Default RE: My Rear
ORIGINAL: RCars2
ORIGINAL: drperry
Now you've got me all worried... What's gonna happen when I goose it in 4LO with a V8 under the hood! LOL!
ORIGINAL: rriddle3
lol, could've been worse... I mean hey! maybe if you get drunk enough... lol j/k (assuming you're of legal drinking age of wherever you are...)
Old Sep 18, 2007 | 04:23 PM
Butch's Avatar
Butch is an unknown quantity at this point
Default RE: My Rear
Very nice post Tay!! wow, haha
