Non functional 4X4 : (
Old Nov 16, 2006 | 01:43 AM
Marzocchi65's Avatar
Marzocchi65 is an unknown quantity at this point
Default Non functional 4X4 : (
So... I've got this problem with my 4x4. I can activate the transfer case and I can lock it into low 2X4 and it's actually in low but there is not 4X4 going on, just the rear wheels. I was wondering if anyone has any suggestions of what might be going on? I thought it might be the splines on the front but then I thought about it and it was just one day offroading where they both wouldn't work and there was no hard use if it before. so basically I was hoping that there is possibly a sensor that has gone bad or something that is easier to replace and cheaper that the rods. Thanks. (1998 4X4 LT Blaze)
[IMG]local://upfiles/3414/272D6B6877F94CA58B8782D184950BD2.jpg[/IMG]
[IMG]local://upfiles/3414/73F81236F6C64F96BAC8CB6E5F99D4F6.jpg[/IMG]
Old Nov 16, 2006 | 02:03 AM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: Non functional 4X4 : (
this thread is totally gonna be moved to general tech help....
Old Nov 16, 2006 | 05:24 PM
dirtyzr2's Avatar
dirtyzr2 is an unknown quantity at this point
most likely its your vacum actuator i have a 02 zr2 that just had the same problem its right under the battery you can take out the battery and the tray and it should be sittin right there check the rubber all the way around make sure no holes or anything its pretty cheap to replace i think it was like 30 or somthing i dont know under 50
Old Nov 24, 2006 | 04:26 PM
Yup, that was it. I can't tell you howmany mechanics I talked to about it and the best thing I got out of them was the splines being stripped. Thanks for the help. Cheap easy fix. Thanks
matthew.chapman1
Feb 12, 2010 02:00 PM
mjcobe89
Sep 10, 2009 09:02 PM
sledneck16
Sep 8, 2009 08:59 AM
Lower_Level
Jan 7, 2009 02:08 PM
illinois99blazer
13
Dec 2, 2008 07:20 AM
